Can too much transmission fluid hurt the shifting of the transmission??? - Page 2 - Fuelly Forums
Old 02-12-2006, 03:43 PM   #11
Compaq888's Avatar
Re: I used a hand operated pump
I used a hand operated pump that I got from Autozone or someplace like that. It had a hose small enough that fit down inside the transmission dipstick tube. Much easier than taking the pan off and only takes a couple of minutes.
I'm too broke now. I'm doing it the old fashined way, take out the dipstick and wipe it a couple of hundred times.
Old 02-12-2006, 03:52 PM   #12
yeah too full bad
Yeah too full is bad - foams and adds drag - loosen a fitting to the oil cooler and let it leak out.
Old 02-12-2006, 03:52 PM   #13
Should sucked it out with a straw or something, that's what I did to my friend's once.
Old 02-12-2006, 05:32 PM   #14
Compaq888's Avatar
I took out about 8 ounces,
I took out about 8 ounces, size of a regular drinking cup. I can't take it down to oem levels because I have a aftermarket oil cooler. I drove for 40 miles the gauge didn't move much. We'll see how the next take will be. This one is ruined for sure since I did a lot of 4K idling.
Old 11-12-2008, 09:08 AM   #15
Smile Here is what I learned
Well, here is what I learned from a well written book ?Complete Car Care Manual? published by Reader?s Digest (1981, page 202). ?You may accidentally overfill it and cause as much damage as you would by operating the car with too little fluid? with regard to overfill of automatic transmission fluid according to the book.
kirk37 is offline   Reply With Quote
Old 11-12-2008, 09:30 AM   #16
What are you? talking about and? why did you bring up this nearly 3? year old thread?
KU40 is offline   Reply With Quote
Old 11-12-2008, 09:30 AM   #17
Haha, thread digger!
What better way to make your into than to reply to a couple year old thread.
- Kyle
Problems with my Volt fuel-up keleko Fuelly Web Support and Community News 16 08-08-2013 11:04 PM
Adding the 2013 Ford Fusion Energi? JDsEnergi Fuelly Web Support and Community News 1 06-27-2013 12:49 PM
Distinction in 'garage' for cars we no longer own Smitty Fuelly Web Support and Community News 3 09-12-2008 06:50 AM
