Eagle Research EFIE Online ... - Fuelly Forums
Old 09-17-2007, 11:32 PM   #1
cfg83's Avatar
Hello -
I have had this gizmo online since August 8, 2007, but I am still messing with it, so it is NOT in continuous use :
Electronic Fuel Injection Enhancer (EFIE) Device
http://www.eagle-research.com/store/...products_id=16
Attachment 928
I am monitoring it's behavior with this :
Air/Fuel Ratio (AFR) Gauge Online ...
http://www.gassavers.org/showthread.php?t=4741
It is connected as follows :
Attachment 927
Here is a youtube of it in action :
EFIE Gizmo
http://www.youtube.com/watch?v=hKWG40hzSeU
In the above video, the EFIE setting is "mild" when it is on. I am trying to add a small fuel trim that still allows for moderate acceleration.
Here is my interpretation of what I am seeing with the EFIE. When the EFIE is on, the A/F ratio creeps up to 14.7 + deltaT. The deltaT is a function of how high I set the EFIE. But, I also have a second post-cat 02 sensor that is used to manage emissions. Because the second 02 sensor is telling the ECU/PCM that the car exhaust is running lean, I think the ECU/PCM tries to resolve the difference by jumping back to 14.7, and then creeping up again. Therefore, I think the result of the EFIE is that instead of floating close around a "narrow ratio" of :
14.7 +- .2
It is now floating around the deltaT with a much wider span :
(14.7+deltaT) +- deltaT
What this means for my EFIE is that I still go back to 14.7, but I spend alot of time "floating up" above 14.7 before going back down.
Notes :
- Since the ScanGauge does not use the short/long term fuel trims, I don't think it is registering the effect.
- I don't like the teeny-tiny screw. It would be nicer if it had something I could tap into. If the screw was on the opposite side, at least it would be easier to package with a hole for inserting a small screwdriver.
- It's output-bias-voltage is temperature sensitive. I wouldn't mind this, except for the fact that I didn't find out until after I bought it. That detail should be on the website. I intend to package it in insulation.
- I may make it a "no load" option for now. If I tap into the TPS signal, I can make it so that it will only be on when the TPS is zero, and off when I accelerate. That way, the engine will simulate "diesel going lean" under idle/no load conditions.
CarloSW2
ID:	790   Click image for larger version
Mobile Site Extremely Slow TheStealth Fuelly Web Support and Community News 0 09-05-2013 07:07 AM
Uploading old fill up info Electra225 Fuelly Web Support and Community News 2 05-20-2011 08:29 AM
Where can I get coroplast? OdieTurbo Aerodynamics 10 06-19-2007 11:28 AM
New member /2007 Prius billynjoanna Introduce Yourself - New member Welcome 10 06-09-2007 10:56 AM
hi SuperRobot46000 Introduce Yourself - New member Welcome 6 07-15-2006 06:44 PM
