Got a 94 VX! But... a couple little problems.. - Page 2 - Fuelly Forums
Old 05-17-2008, 07:27 PM   #11
Send a message via AIM to limerence
my speedo is the same way. replaced the vss did nothing. will look for a cluster to replace it. anyone got DIY's to take off the cluster and swap in another?
limerence is offline   Reply With Quote
Old 05-17-2008, 08:42 PM   #12
Is the cluster VX specific? I would think this engine has a different redline and speedo combo than something like an SI.
Hopefully the A/C is just low on gas... doesnt blow cold air at all.
jshelton441 is offline   Reply With Quote
Old 05-18-2008, 04:03 PM   #13
Danronian's Avatar
You're lucky to even find a VX with a/c since most didn't come with it.
I had my speedo stop working on my VX due to the connector on the VSS being corroded. Where it sits water can just go straight into it, so that is something that is worth looking at.
The cluster is VX specific since it does have a different redline and a shift-light on most non-CA models (where the cruise light would be in the other clusters). If you can't find the VX one, you could get a different one and swap in your VX tach.
Old 05-18-2008, 05:10 PM   #14
Search for a pdf online manual.
Buy the parts online, maybe from Majestic Honda.
Do all the repair work yourself, or hire a mechanic.
Or suck up the high cost of getting it repaired at a Honda Dealer!
JESSE69 is offline   Reply With Quote
Old 05-19-2008, 04:55 AM   #15
Thanks guys I see a few clusters for sale on ebay, the redlines are only 500RPM different so I will probably just swap it in. The revlimiter will still be the same. I will check the connector at the VSS first and use some contact cleaner on it either way. Thanks for all the help you guys know your Hondas.
Anything wrong with the 08 Honda Fit? jeffreymccoy Car Reviews 35 11-27-2007 09:14 AM
Saturn idle RPM changing according to speed Fourthbean General Maintenance and Repair 5 09-25-2007 09:15 PM
gassaver.org members on facebook 88HF General Discussion (Off-Topic) 0 08-25-2007 11:31 PM
