Honda NOID Light, Which to use? - Fuelly Forums
Old 10-27-2006, 09:47 AM   #1
I want to check to see if my injectors are getting a proper signal to conclude wether its my injectors or something else (i get error code 16). They sell kits that iclude the followoing noids;
  • GM TBI
  • Bosch PFI
  • Ford TBI
  • GM PFI
  • Geo TBI
  • GM SCPI
Is it the Bosch PFI Noid that i have to use? Or is the Honda Noid not on the list?
Thank you in advanced.
8Civic8 is offline   Reply With Quote
Old 10-27-2006, 10:55 AM   #2
I have no idea, but have you already checked your main relay and wiring (if you changed any wiring)? What's a NOID?
Old 10-27-2006, 11:19 AM   #3
Yeah, ive ran through the honda manual a few times and everything checks out. I have proper voltage, the injectors are injecting gas, it leads me to replace ecu, i replaced the p07 with a p13 ( that i know is good). And i get the same message. Could it also be that i repaired the TPS and the idle is all screwy since i did not calibrate it (i didnt know i had to at the time i did it)? ( what i mean by repaired is that i got a jdm engine and the tps clip was broken but the leads where still there. I couldnt get close enough to it to sauder so i took it off and saudered some wires to it and put it back. I have a feeeling that it might be the irregular idle thats throwing off the ecu and making it think that its a injector malfunction.
Does anyone know if a 88 civic (D15 DPFI) TPS will fit a d15z1? THey should but i dont know.
Any idea?
Old 10-27-2006, 12:21 PM   #4
Did you swap the wires on the TPS?
Also, are you using an injector resistor box or not?
Old 10-27-2006, 12:24 PM   #5
Do you mean connect them improperly? I dont think so. could that be it?
Old 10-27-2006, 12:29 PM   #6
For the tps you need to switch the two outer wires when you do the MPFI swap. Dunno if that causes a code 16 though.
What's your injector/resistor box situation?
Old 10-27-2006, 12:32 PM   #7
I dont have one. I dont think the original DPFI wire harness had one. Where would it be if i had one. I didnt take one out, if i had one then its probably still there. Although, isnt it ussualy on the drivers side shock tower? because there is nothing there.
Old 10-27-2006, 01:00 PM   #8
By the way, a NOID is a test light that checks for signal coming from the injector harness. It lets you know if theres a problem with the wiring harness.
Old 10-27-2006, 01:26 PM   #9
Matt Timion's Avatar
Noid?
Avoid the Noid.
Old 10-28-2006, 05:46 AM   #10
Tuggin at the surly bonds
Silveredwings's Avatar
Noid?
:Noid image:
Avoid the Noid.
He looks like he's annoyed.
Help...MPG calculator not working djquik1 Fuelly Web Support and Community News 1 10-18-2010 04:57 AM
Support for motorbikes wrighth1 Fuelly Web Support and Community News 9 08-18-2008 06:11 AM
Ever wonder how wind will effect your mileage? Lots of interesting Prius info krousdb General Fuel Topics 4 02-08-2006 07:49 PM
My paint job saga... with pictures of the finished product Matt Timion General Discussion (Off-Topic) 9 01-04-2006 07:16 PM
Any ideas how to install this? Compaq888 General Maintenance and Repair 0 12-21-2005 12:46 PM
