oil filter on a saturn?!?!? - Fuelly Forums
Old 08-04-2009, 01:13 PM   #1
Im going to change the oil on my moms 2001 Saturn SC-1 here this week and I cant seem to find where the oil filter is located on this thing. Help me out please!!!
yaris0128 is offline   Reply With Quote
Old 08-04-2009, 02:22 PM   #2
i'm not familiar w/ that year and model, but i had a 95 SL1. it was located inside the passenger side wheel well, mounted horizonally, not vertically. this may explain why it's difficult to locate.
i used to take the wheel off to change it. but if you're more skilled, this may not be necessary.
Old 08-04-2009, 02:27 PM   #3
FYI...
if it's an auto, like my 95, the tranny service is very simple as well. it has a drain plug(no gasket or pan) and a spin-on filter like the oil filter.
i would take out the air cleaner assembly for super easy access to that filter!
Old 08-04-2009, 02:39 PM   #4
GasSavers_Erik's Avatar
On my sister in law's 1999 SC1, the oil filter is directly under the power steering pump (between engine block and firewall) it can't be accessed from the top of the engine bay.
Old 05-29-2014, 10:38 PM   #5
You will need to raise the car on the front passenger side and must also use jack stands to work safely. There are two oil filters under the car. The orange filter is for the automatic transmission and is located nearer to the driver's side of the car. The engine oil filter is behind the engine near the passenger side front wheel well. You will need plenty of rags to catch the old oil when you remove the filter, oil will spill all over the frame member when you remove it. Make sure to check that none of the old filter gasket material remains on the filter mounting surface before you install the new filter.
dobrien14328 is offline   Reply With Quote
WTB: VX Cluster limerence Wanted to Buy 1 05-28-2008 07:45 PM
Are these wheels worth it? Improbcat General Fuel Topics 17 05-24-2008 04:01 AM
Second odometer for WVO tank? Jetta90GL Vegetable Oil and BioDiesel 2 03-24-2008 12:17 PM
