Replacement of Prius plugin 12 volt battery - Fuelly Forums
Old 08-23-2017, 05:47 AM   #1
Dealer recommends replacement of 12 volt battery in my Prius plugin. Any reason why I should not do this myself?
priusplugin0077 is offline   Reply With Quote
Old 08-23-2017, 06:46 AM   #2
I don't know what year you have, but I recently replaced the accessory battery in my 2008 model. It's located in the trunk and requires you to remove some panels and possibly a control box of some type. It took me nearly an hour, but that was because the battery had died, we couldn't move the car, and it was in a short garage where I couldn't open the trunk all the way. If you have basic skills you should be able to do it with some help from the internet.
arcticshrike is offline   Reply With Quote
Old 08-23-2017, 07:22 AM   #3
As I stated in the other thread, make sure to get a vented battery and connect it to the vent lines.
Old 02-19-2018, 10:49 PM   #4
You should start thinking about replacing the battery every 5 years.
mohenry is offline   Reply With Quote
Tags
12 volt battery, prius plugin
