11-14-2007, 10:57 AM
#21
Originally Posted by BIBI
I read on superhonda.com few years ago that it is not recommanded to use Seafoam on a engine that as more than 93-94 000 miles on it (150 000km). My VX have 135 milles on it, and its the reason why I didn't do it (got the car at 94 000miles but didn't think about doing it at the time.
So would you use in on a 135k miles engine, I will probably go to a honda dealer to do it for me (so doint a de-carbonizing, maybe not using seafoam, don't know,,,)
My motor has around 130k on it, and it loved it! haha
11-14-2007, 11:13 AM
#22
GREAT, I'm going to honda tomorow to take an appointment, I WANT MY IDLE BACK (actually at around 900 to 1000 rpm).
Hehehe 94k miles, Tomo's got like over 3 times that, thats convincing. If my vx can do an other 200k miles, I would be blown away!
11-14-2007, 11:20 AM
#23
My motor isn't in the greatest health. There's nothing majorly wrong with it. The valve stem seals are a little worn and allow some oil to be burned, as well as the piston rings are wearing too. Last compression check (done two or so months ago) yielded a solid 200-196psi across the board though.
BIBI - does your VX idle that high when you have the climate control fan off along with the lights off and your foot off of the brake?
Honda Civic VX Info/Links
Originally Posted by ezeedee
11-14-2007, 11:29 AM
#24
Originally Posted by TomO
Just remove the top tube (the one that goes back towards the fender in front of the airbox) then you can see where you can attach the dryer hose and just run it to the manifold. I used a length of mechanic's wire to hold the dryer hose to the upper radiator hose for support.
What happened to the Whale Penis?
[SIGPIC][/SIGPIC]
11-14-2007, 12:19 PM
#25
^^^ I just snagged that picture off of the internet as a reference because I have the "Whale Penis" aka. J's Racing Style intake still in the car for winter.
And with that, I have no way to think of getting this thread back on topic, sorry.
11-14-2007, 12:23 PM
#26
Gee, I Seafoamed mine last week at 255,xxx miles. It didn't seem to care much one way or the other.
11-14-2007, 12:36 PM
#27
Depending on how much buildup and what motor it is, as well as method of decarbonizer delivery, there may be little to no noticeable difference as well. YMMV
11-14-2007, 01:04 PM
#28
i just seafoamed my chevette and the awesome smoky cloud of doom. i dunno if it helps but ive had it in the crankcase for the last 300 miles and that oil came out BLACK...put exactly 4 qts in and right up to the full line. we shall see if it helps fe any
11-14-2007, 01:08 PM
#29
Can't you just run 24-28 oz of water through the brake booster line and get the same results?
11-14-2007, 02:35 PM
#30
I've heard that too, though running water through my motor scares me too much to try that.
