92 VX bad milage - Page 3 - Fuelly Forums
Old 05-21-2011, 06:21 PM   #21
Re: 92 VX bad milage
It certainly does not belong there. Maybe the primary cat failed and instead of changing it, the previous owner added a second to pass emissions.
I exit lean burn when my life is at risk.
1998 Odyssey 24.1 mpg average
1984 crx project now on the road
hondaguy72 is offline   Reply With Quote
Old 05-21-2011, 08:21 PM   #22
add|ct's Avatar
Yes, go back to stock exhaust. If you have a plugged(worst case scenario?) primary OEM cat at the 02 sensor, plus an aftermarket. This could explain the bad mileage.
'92 Civic VX, Canadian model
Old 05-21-2011, 09:12 PM   #23
imzjustplayin's Avatar
Kinda interesting.. I mean I guess you could try to see if the primary is clogged/bad and if it's bad but not clogged, maybe you could continue with this setup since it looks kinda nifty and I find it amusing.
Old 05-21-2011, 10:48 PM   #24
alright ill have it remove this coming week. also if the oem cat is clog can i use the one from a 96-00 civic d16y7? also how can i check if the o2 sensor is bad since it looks new .
noender is offline   Reply With Quote
Old 05-21-2011, 11:04 PM   #25
also if the o2 is bad can i just get the aem wideband kit....the o2 sensors are running at 300 in autozone, oreilly ....
http://cgi.ebay.com/ebaymotors/AEM-G...Q5fAccessories
Old 05-21-2011, 11:23 PM   #26
benfrogg's Avatar
Standard makes an 02 for this car, I'll have to search my prior posts for the model number. It was about $75 and is no better than the $200 sensor I bought (NTK/NGK 24300) which is the right one. Run the test in the shop manual/helms manual to determine if it's working. Do you have any CEL codes?
As for the cat, you need to check it's plugged. You can use a pressure gauge in the 02 hole to determine this. The cat's for these aren't cheap either, I think they run over $300.
There would be no other reason to run that cat unless the old one would not pass emissions. If the old one didn't pass emissions, it was probably also plugged. When I pulled mine to replace the gasket, I flipped it over on the garage floor. It dumped a couple handfulls of sand-like material onto the floor. I could feel the difference in the car when I got it all back together.
B
Which Saturn SL for the best MPG's Drahthaar General Fuel Topics 12 09-10-2010 01:07 PM
Why do pulse jets lose power at high speed? GasSavers_maximilian General Discussion (Off-Topic) 5 06-10-2009 08:05 PM
Tires and Airtabs oh my! kitcar Experiments, Modifications and DIY 5 07-19-2008 05:31 AM
Finally got some LRRs rh77 General Fuel Topics 4 10-03-2006 08:16 PM
