Adjusting auto tranny fluid pressure - Page 3 - Fuelly Forums
Old 07-25-2008, 02:34 PM   #21
Originally Posted by RoadWarrior View Post
Don't know, but if you've got a transmission that needs a special synthetic like Mercon V or a 7176, ATF +4 spec fluid, then don't mess with it. If it takes regular ATF, then it's probably not so fussy.
Actually if you're using a synthetic "just because" you might want to try some of the synthetic chrysler ATF +4 which has larger amounts of friction modifiers than "regular", then at least you're blending synthetics.
my T-350 takes 10qts ,,i have 8 Dext/mercon 1 type F and one ATF +4 in it
COMP is offline   Reply With Quote
Old 07-25-2008, 03:46 PM   #22
I'm using "practically synthetic" TDH UTF (Universal Tractor Fluid) made out of high grade high VI group 3 base stocks (Which some motor oil manufactures claim they can call synthetic these days) that has friction modifiers intended for heavy duty wet brake and wet clutch use in industrial and agricultural transmissions... plus it's only $7 a gallon
Old 07-25-2008, 03:50 PM   #23
you using that in the Ford and the Dodge ?
Old 07-25-2008, 04:14 PM   #24
Just Marvin so far. Wile-E was doing great with fresh ATF plus a dose of Lucas, when his motor is back together, I'll probably consider it next spring. Might need to use lucas in it to color it for him (it's clear) he has some optical sensors for clutch pack modulation.
Old 07-25-2008, 04:35 PM   #25
where did you buy it ??
Old 07-25-2008, 08:02 PM   #26
At the evil emporium of he who must not be named, ummm *cough*walmart*cough* Actually always seem to end up there for my fluids when nothing is on sale anywhere else. Supertech/tech 2000 synthetic oil is a good bargain too.
Old 07-25-2008, 08:08 PM   #27
i agree ,,,i hate the place ,,,,,,,,,,,,,,,,,,,,,,,,,but i go cause of some good deals ,,,thanks
Adding the 2013 Ford Fusion Energi? JDsEnergi Fuelly Web Support and Community News 1 06-27-2013 12:49 PM
Basic Stats darkangel7 Fuelly Web Support and Community News 2 11-21-2010 04:29 PM
electric l/100km MJ/km Efried Fuelly Web Support and Community News 2 08-25-2008 07:41 AM
