Pulse and Glide with an auto - Page 2 - Fuelly Forums
Old 11-25-2006, 04:22 PM   #11
When you do EOC or p&g your car, does your temp gauge skyrocket? I did it a few times in my car, but when i restart it i find the temp gauge nearly pegged :O this seams real bad for the car, so I usually dont' do it.
Old 11-26-2006, 04:18 AM   #12
I P&G'd for abot 25 miles both ways yesterday. My normal coolant temp is 192-195. The SG1 recorded a peak temp of 210.
The temp spikes when you P&G because you load up the engine and then kill it before it has the chance to dissipate the extra heat generated in the pulse. So you have a mini hot-soak event every time the coolant stops circulating.
By the time I re-start, the "average" coolant temp has probably dropped a few degrees below the normal operating temp - I sometimes see mid/high 180's on the gauge for a few seconds when I restart.
So.... I try not to kill the engine immediately after loading it up. I let it idle in neutral for a count of 3 at the start of a glide, and then kill it. It probably doesn't make a huge difference for hot-soak.
Old 11-26-2006, 09:25 PM   #13
Peakster's Avatar
Originally Posted by MetroMPG
But it's like anything else. After you do it enough, it becomes automatic and you don't really think about it while doing it.
That is very true. It almost killed me to stop hypermiling because it felt so natural to do so. I tried P+G when there was little traffic at night, only I did it at 30-35 mph and turned off the engine while gliding. It was a lot of work though and I stopped because it's getting too cold outside (the heater turns cold when the engine isn't running).
Old 11-27-2006, 06:08 AM   #14
Peakster: do you have your grille blocked? That'll help.
Old 11-27-2006, 11:13 AM   #15
psyshack's Avatar
P&G should not effect coolent temps if at all. There might me some smallish spikes here and there.
With a sealed or semi sealed cooling system thermal dynamics force the bulk of the collent around and in the cooling system. Water pumps mainly circ. the cabin hot water loop. This is not to say they dont help with the flow of water to and from the rad. and block.
If a car is showing signs of over heating while P&Ging. I would check the thermostat and rad. cap. And if that ok and your still seeing alot of temp spikes or over heating action a good flush might be needed for the block, head and rad. I would do a flush very gental like. Getting dirt out of the system is hard on the water pump seal.
09 HCHII, w/Navi
07 Mazda3 S Touring, 5MT
Mild Hypermiler or Mad Man?
Old 11-27-2006, 12:39 PM   #16
I'm more afraid that maybe the transmission is heating up the coolant excessively in the neutral cruise? I just did a whole cooling system flush and refill, so it's not that. The only time she ever overheats is during P&G I think it's too old for P&G anywyas, so I'm going to focus on normal driving economy.
Old 11-27-2006, 04:34 PM   #17
psyshack's Avatar
Really? Say you have a hot engine- take the radiator cap off and run it- see the coolant shooting into the radiator? Shut it off- see the coolant not shooting into the radiator any more? I think it would act the same if the heater circulation was stopped.
How do you do a harsh enough flush to affect the water pump seal?
Ok how to explain this.
Have you ever heated something up in a microwave and noticed the lid has either popped off the container or is bulging a lot? This is pressure. Then you pull it out and set it on the counter and the lid then pulls down as the food and moisture cools? This is a basic vacuum.
As the water heats in the water jacket in a car it expands. IE the reason radiator caps have a psi rating. As the water is cooled in the radiator it goes into a vacuum if you will. So when the thermostat opens were does the water want to go? Twords the cool vacuum. Also if you ever take a radiator cap off at the wrong time you will get burnt bad due to the psi. The thermostat can be closed say just after the hot water got in the radiator. If you have a 12 psi radiator cap and 10 psi in the radiator,, guess what you just got burnt. If the water has had a minute to cool nothing will happen when you take the cap off. You might even see the fluid level rise a slight amount. The water pump will help some no doubt. But basic psychics rule the roost on this one.
The water pumps real reason for being is circ'ing the heater core. The heating system is on the high side if you will. The pump creates differential pressure to move water thru the heater core. We know there is pressure drop across the heater core. So enough psi has to be made to flow the core. If you shut the motor off the core cools with air being blown over it. No pump no flow. With equal static psi on both sides of the coil.
As for the water pump seal and flushing the system. If you have a cooling system full of dirt and other stuff. You have major problems. Dirt is the number on killer of mechanical seals and lip seals. The other killer is no water. Dirt eats up the sealing surfaces and a seal will fail fast. Running one dry will ruin it also. The water is what makes the seal and it also cools the seal surfaces. If a seal is ran dry what water is in the sealing surface will boil making these tiny explosions between the seal surfaces and causing pitting. Soon as you have pitting from over heating or running dry the seal surfaces or scratchs from dirt. The water tension will not make the seal and psi will force the water out between the sealing surfaces.
Standard materials for mechanical seal are buna or viton for the elastimers with carbon type material and either a ceramic or durametalic matrial for the sealing surfaces. Tis goes for full face seals or lip seals. Most of these basic seals have a max temp rating of 220 degrees F. Most of these seals have a max psi rating from 125 psi to 175 psi in basic config's.
I hope this helps.
psy
09 HCHII, w/Navi
Old 11-27-2006, 11:35 PM   #18
psy
The top didnt pop off , what shall i do next ?
google+ integration? xchrislee Fuelly Web Support and Community News 3 07-15-2011 01:55 AM
Bug with car image upload dstretch Fuelly Web Support and Community News 6 01-26-2011 03:58 AM
A Visual Look at Optimum Drag Coefficient (Cd) Mighty Mira General Fuel Topics 18 03-08-2008 02:56 PM
Airspeed indicator for your car basjoos General Fuel Topics 32 03-29-2006 01:23 AM
