Exploring A New Idea - Fuelly Forums
Old 07-24-2008, 03:31 PM   #1
Single-shot injectors.
My 7.3 uses split-shot injectors. Two small squirts per injection event. Quiets the engine but imposes a degree of timing retard. Using single shotters from the earlier Powerstroke I get a more efficient combustion event.
2000 Ford F-350 Super Cab Pickup
4x2, 6 speed manual
Regeared to 3.08:1
4 inch suspension slam
Aero mods: "Fastback" fairing and rugged air dam and side skirts
Stock MPG: 19
Summer MPG: 27.0
Winter MPG: 24
Big Dave is offline   Reply With Quote
Old 07-25-2008, 04:28 AM   #2
My opinion is that a continuous injection throughout the power stroke is more benefitial than slamming the piston top, at or very near TDC, with the full fuel charge. The crank angle is such that the force produces little torque just past TDC, but the roughly 90 degree angle of the connecting rod to crank halfway through the stroke is able to produce more torque.
There has to be some fuel injected at TDC to take advantage of the compression heat and allow self-ignition, but withholding some of the fuel for injection (and using prior fuel's heat to ignite that late volume) until later in the down stroke when conversion from piston pressure produces less direct down load on the crank bearings and more torque from the nearer 90 degree angle can make more power on the same fuel with less noise and lower emissions, too.
The new common rail TDI from VW uses 7 separate injection 'pulses' per power stroke to keep quiet and to meet 50 state emissions requirements.
Old 07-25-2008, 04:40 AM   #3
GasSavers_SD26's Avatar
Dave is this something that you're thinking about or trying?
My E350 is a '96 and has single shots. The new to me Excursion has the split shots.
Dave
Old 07-25-2008, 04:42 AM   #4
Since you have a six speed, can't you take the plug off the EOT sensor and get timing advance? If that's what you were looking for.
Dave
Old 07-27-2008, 06:15 PM   #5
I'm in negotiation to get it done.
A lot of guys I respect seem to think this is more efficient. The engine was designed for single-shots.
We'll see. Wouldn't be the first thing I've tried that didn't work. Free-flowing exhaust and warm air intake gained me squat.
4x2, 6 speed manual
Regeared to 3.08:1
Stock MPG: 19
Summer MPG: 27.0
Winter MPG: 24
Old 08-01-2008, 05:07 PM   #6
Going to Nashville the 11th for single-shots.
4x2, 6 speed manual
Regeared to 3.08:1
Stock MPG: 19
Summer MPG: 27.0
Winter MPG: 24
Old 08-01-2008, 05:17 PM   #7
Ok, who's doing the tuning? More info, more info!!!! $$$? (The scary stuff)
Dave
Old 08-02-2008, 11:57 AM   #8
Swamp Donkey is doing the injectors. I'm a bit fuzzy about the tuning.
My guess is about a grand, but remember I need injectors antway. Its getting crotchety to start and I get a puff of black smoke on startup. My injectors (with 217,000 miles on them) are dribbling when cold.
4x2, 6 speed manual
Regeared to 3.08:1
Stock MPG: 19
Summer MPG: 27.0
Winter MPG: 24
Old 08-02-2008, 01:55 PM   #9
Is the dribbling common with age?
Or is it common to the split shots?
Dave
Old 08-02-2008, 06:12 PM   #10
My understanding is that the check valve at the tip does wear out. It is cycled thousands of times a minute.
4x2, 6 speed manual
Regeared to 3.08:1
Stock MPG: 19
Summer MPG: 27.0
Winter MPG: 24
Help Needed! thewolfwagon Fuelly Web Support and Community News 2 05-17-2012 04:44 PM
Car not showing in browse vehicles Armegatron Fuelly Web Support and Community News 1 01-17-2012 03:15 AM
Fuelly for international? pixelthing Fuelly Web Support and Community News 8 08-11-2008 07:32 AM
Ya another noob pizza dude Introduce Yourself - New member Welcome 22 11-16-2007 09:18 AM
OBDII Questions krousdb General Maintenance and Repair 1 05-07-2006 04:18 AM
