01-12-2011, 11:05 PM
Natural Gas
Anyone do a CNG conversion to their diesel?
I would want to be able to switch back and forth between Natural Gas and Diesel.
The problem in California is that the CNG vehicles use it exclusively, which isn't bad for Fed Ex, UPS, USPS and taxi fleets, but I run longer distances so having a vehicle that would run on the under $2.00 fuel until it ran out then I'd switch to conventional fuel.
01-13-2011, 05:46 AM
Re: Natural Gas
Dunno about natural gas, but there are propane kits available for diesels. Natural gas requires high pressure tanks, propane less so.
01-14-2011, 05:13 PM
Re: Natural Gas
Really!
I was just thinking a sparkplug was necessary.
01-15-2011, 12:54 PM
Member
Re: Natural Gas
The propane kits for diesels are for adding propane to the diesel fuel, it apparently helps the fuel burn more completely.
But not to run a diesel engine exclusively on propane!
01-16-2011, 12:02 PM
Re: Natural Gas
i've only heard of propane kits for diesel in the context of generating more power. The idea being it's cheaper and faster than swapping out the fuel system and can be switched on/off. Since diesels don't match air to fuel ratio (well, they do some but in general it's not required) to make big power you bolt on a big turbo which gets the air in. If you're already running richer than needed (black smoke) the net result is cleaner running and more power. [here on I'm putting together as I type so i could be wrong] at some point it's impractical or overly expensive to add more diesel via pump/injectors so to add fuel to the overly lean combustion chamber, you inject propane which burns alongside the diesel (and more cleanly) not as much BTU/gallon but something about it works well side by side w/ diesel. the end result (lots of power at the push of a button) is similar to that of nitrous on a gasoline engine
as for switchable dual-fueling a diesel (other than BD)... I'm not sure. AFAIK almost everything else is spark-ignition. Also, AFAIK, propane and CNG/LNG are both carburated or port injected and might preignite at diesel compression ratios (course then again maybe not since they use propane in tractor pulls. I dunno *shrug*). part of the reason diesels use compression ignition is that it's so hard to ignite to start with. another other problem I imagine is that most diesels are in heavy duty or already very high FE applications where torque is king. 130k btu/gal is a LOT more than propane (90k) or LNG (85k)
-Russell
01-16-2011, 05:24 PM
Re: Natural Gas
Just checked in as I'm going to bed so I can't explain it all, but;
Propane is a catalyst. In other words, air/fuel burns at a certain efficiency, air/propane/fuel burns at a higher efficiency.
Think of frying something in a pan dry, then you add butter or oil, the heat can transfer through the oil and have more contact with the food than just the food on the pan. The oil/butter is like a catalyst. The food will cook without it, but the food cooks more efficiently with it.
Strange analogy...I must be tired! LOL!
Oh and the bump in hp is because of the amount of propane injected. I made my own propane inj system and while it smoothed the engine out and made it run much better/cleaner, it only raised the mph about 5-8mph with it on as opposed to it off. Found out I was injecting way to little to boost much of anything. And, the amount I would pick up in mpg would not cover the cost to refill the 20lb bbq tank. (the bbq tank was the problem, I'll explain further sometime)
11-10-2011, 12:56 AM
Re: Natural Gas
hi, you all find out my this post is little bit different but yes exactly i am talking about Natural Gas in Greece, Serious scientific evidence shows that the sea area south of Crete holds a wealth of oil, mainly gas, capable to solve the economic problems of Greece, but also to address the issue of unemployment.
The identification was made by professor emeritus Antonis Foskolos of the Department of Mineral Resources and Engineering of the Technical University of Crete, and emeritus researcher at the Geological Survey of Canada, who will speak tomorrow at the Greek Geological Society and the day after at the Economist Conference in Lagonissi.
According to Mr. Foskolos, the proclamation of a Greek Exclusive Economic Zone (EEZ) has a huge economic and geopolitical importance as they will achieve:
- Exploiting the potential of rich offshore oil deposits in the south of Crete
- The gas pipeline that will pass through the Greek EEZ for the transport of very large quantities of gas runs in the eastern Mediterranean and Crete.
According to the professor, "the 2 areas that have significant scientific evidence is south of Crete, are 9 mud volcanos southeast of Crete, in the Greek Herodotus basin. More: South of Crete, namely around mud volcanos should be no hydrocarbon reserves, but primarily natural gas, approximately 1.5 trillion cubic metres. This is comparable with what has been found in the Nile Delta, the Caspian Sea (deposit Shah Deniz), Norway and elsewhere.
Southeast of Crete is the basin of Herodotus. The Greek part of the basin must have probable reserves of the order of about 2 trillion cubic metres, in line with the discoveries of natural gas in the Nile Delta (SHELL, BP), a very recent study by OMV and estimates of potential gas reserves in the Cyprus section of the basin adjacent to Herodotus the Greek part of the basin of Herodotus . The sediments are of the same origin and geological formations very similar. Of all the potential 3.5 trillion cubic metres gas deducting an amount of 0.75 trillion cubic metres for the elimination of import of crude oil for 25 years, which shows a saving of about 223.75 billion U.S. dollars'.
BENEFITS
For general benefits for Greece, Mr. Foskolos notes, inter alia, that the recovery - exploitation of these deposits will create at least 100,000 jobs in the primary sector and 200,000 jobs in the secondary sector, a total of 300,000 jobs, while all revenue to be reaped by the Greek state in 25 years amounts to 437 billion U.S. dollars and the rate of the dollar to the euro to 302 billion, not counting the profits from the pipeline transportation of natural gas to Europe, at a lenght of 1000 km at a cost of approximately $ 20,000 / km, or 25 billion U.S. dollars.
Professor Giannis Makri agrees with Mr. Foscolo: "There are two potential hydrocarbon reserves southwest of Crete, where sediment has a thickness of 10 to 12 kilometer, and hydrocarbon reserves in Western Crete, where there are 3 fields of mud volcanos.
It is absolutely necessary to undertake three-dimensional high-resolution geophysical surveys under the evaporites throughout southern Crete to discover the size of deposits of hydrocarbons. The cost is estimated at 6 million. "
11-10-2011, 06:58 AM
Re: Natural Gas
Greece has the same problem with developing resources as America now does.
Government.
11-14-2011, 07:47 AM
Re: Natural Gas
Propane and natural gas are fuels, not catalysts.
Both propane and natural gas may be used in diesel engines, but a small amount of pilot oil must be injected in order to ignite the gas. Here is a link to an interesting diesel that burns up to 99% natural gas:
http://www.fairbanksmorse.com/about/enviro-design/
Propane systems sold for diesels as a simple way to make more power. Modern emisssion controls limit the amount of fuel burned to prevent smoke / particulate emissions. Adding propane uses more of the oxygen in the intake air, making more power. Propane fools the controls.
Thread Tools |
Display Modes |
Linear Mode
