Festiva Aerodynamics - Fuelly Forums
Old 06-06-2007, 03:06 PM   #1
XFi
XFi's Avatar
Just got done with a rough grille block. Decided to angle it from bumper to hood. I went with a partial as not to overheat this summer.
Also added are Wheel/Tire Deflectors/Tabs.
Still working towards 50mpg!!!
XFi
Join us for the November 22, 2008 Pennsylvania Meet at Cabela's!
https://www.gassavers.org/showthread....634#post121634
XFi is offline   Reply With Quote
Old 06-06-2007, 03:08 PM   #2
Pictures!?
Old 06-06-2007, 03:13 PM   #3
you mean to tell me those festivas dont already get 50 mpg? what do they get? (i know they can get up to 90 mph tho)
Old 06-06-2007, 04:35 PM   #4
ELF
ELF's Avatar
Your getting close! I advanced my timing on my festiva, then used higher octane gas. Got more power and better mileage. 50 mpg was no problem, but had to keep the speed down to 60mph or less.
Old 06-06-2007, 05:01 PM   #5
XFi
XFi's Avatar
Last two tanks, I have been keeping the speed under 60mph.
I Haven't touched the timing yet. Thanks, after this tank I will
Originally Posted by SVOboy View Post
Pictures!?
Pic now posted.
I'm not sure if I am going to keep it like it is (really stands out) or just cover the grille 'flush'. I guess it depends on my mpg this tank!
Festivas seem to get 35-40 without trying too hard.
New EPA rating 30/37 - 33 combined mpg
(Old EPA 35/41 38 combined mpg)
XFi
Old 06-06-2007, 05:08 PM   #6
Festivas are a rarity around my area ( Metro's on the other hand though! Wow I didn't know they made that many LOL) I rather like the new grill block you've done . If it were me I'd leave it .
Old 06-06-2007, 06:41 PM   #7
boofighter's Avatar
just a thought, if you are not planing on filling in the gap on the sides of the grill block then why not go all the way across? i know that you are thinking of cooling but there should be enough at speed and when you are stopped the fan should be able to pull it in from the sides. same with the one on the bottom. my .02
boofighter is offline   Reply With Quote
Old 06-07-2007, 07:07 AM   #8
XFi
XFi's Avatar
What boo described is pretty much what I have- never gets hot.
May try it. Nervous to do so though...don't want any overheating in traffic. Plus, what is the trade off in regards to the electric fan running more (additional load of the alternator running more)? Any thoughts?
XFi
Old 06-07-2007, 08:23 AM   #9
jwxr7's Avatar
On mine I cut a couple slots in the grill block that I keep clear packing tape over. If it is really hot and I get paranoid about overheating then I pull one or both off. I haven't had any problems with the engine getting hotter than normal. Even on 90 degree days. I forgot to tear off the tape one day leaving work on a mid 80 degree day and still had no problems.
I've thought about that too and wish I had an indicator on the dash so I can tell when the fan comes on, then I'd know if the grill block is pushin the fan alote. In slow city driving it seems like the fan load would be higher than the aero gains.
Old 06-07-2007, 09:53 AM   #10
zpiloto's Avatar
jwxr7 I though you had a SG. Mine comes on at 211 degrees. I run around 200-205 when moving.
fuel economy question Creamycaesar General Fuel Topics 19 02-08-2010 07:37 AM
Another perspective on the oil price drops Matt Timion General Discussion (Off-Topic) 0 09-27-2006 12:23 PM
Hydrogen Generator! SVOboy General Fuel Topics 208 08-06-2006 02:59 PM
How did you first find Gassavers.org? kickflipjr General Discussion (Off-Topic) 17 05-24-2006 07:28 PM
throttleless premixed-charge engine (ultimate WAI) MetroMPG General Fuel Topics 17 01-07-2006 06:49 PM
