Grill Block position? - Fuelly Forums
Old 04-28-2007, 07:33 AM   #1
I currently have mine on inside. was getting a lil wavy so i cut a new piece of cardboard and covered it with some vinyl flashing and zip tied it on. has anyone had gthere on inside and then moved to otside and noticed any difference?? i'm thnking that maybe on inside it might be catching air instead of pushing it around the car.
"Sylvie" 2000 Honda Insight 5 Speed
LxMike is offline   Reply With Quote
Old 04-28-2007, 03:04 PM   #2
I think theoretically it would be better on the outside, but the difference is probably immeasurable.
Old 04-28-2007, 03:06 PM   #3
trebuchet03's Avatar
Ditto - less stagnation on the outside, but given a small surface area - you're likely not to notice Then again, there's no one thing that makes a complex shape aerodynamic (other than a teardrop shape) - it's a combination of a lot of little (and likely subtle) things
11/12
Old 04-28-2007, 07:02 PM   #4
Peakster's Avatar
I would think that placing the grille block flush with the exterior would be best.
BTW, I didn't find any Aero improvement with my grille block, however, the warmup times are shortened greatly.
Peakster is offline   Reply With Quote
Old 04-30-2007, 06:28 AM   #5
brucepick's Avatar
My solution is halfway between in front and behind.
I got a few lengths of foam pipe insulation from Lowe's or Home Depot. Inserted the foam in the grill slots.
Every third slot is only partially filled with foam to let some air in. When the weather warms up for real I'll experiment with adding or deleting foam from slots.
My grill has about 1/2 inch splaces between vertical grill slats (see avatar). I sealed the self-sealing slice in the foam insulation to make it a tube, then squished that flat and stuffed it into the slots. YMMV due to whatever width your grill slots and foam insulation are.
View model averages? unicrombie Fuelly Web Support and Community News 4 11-09-2011 06:32 AM
HF to SI tranny swap complete, questions about tire size... white90crxhf General Fuel Topics 1 08-20-2006 06:46 PM
Gas Log? GasSavers_Kraig General Discussion (Off-Topic) 3 08-16-2006 01:21 AM
Got stopped by the police ... MetroMPG General Discussion (Off-Topic) 14 08-05-2006 06:04 AM
Toyota Grand Prius krousdb Automotive News, Articles and Products 5 07-26-2006 02:44 PM
