List of aero mods - Fuelly Forums
Old 02-10-2007, 12:42 PM   #1
Post List of aero mods
[This thread will be a work in progress.]
Old 02-10-2007, 07:56 PM   #2
kickflipjr's Avatar
Good list metro. I don't think you mentioned side skirts.
2008 EPA adjusted:
Old 02-11-2007, 04:12 AM   #3
I though side skirts were more of a downforce producing mod than a drag-reducing mod. (Combined with a low front air dam they reduce the pressure under the car.)
I've only ever seen them mentioned in handlin/racing applications.
Could be wrong - anyone have any references?
Old 02-12-2007, 01:52 PM   #4
kickflipjr's Avatar
Yeah that picture above definitely has some downforce characteristics in it. I always thought they would benefit aerodynamics because they prevent air from coming in through the side of the car.
Example 2
2008 EPA adjusted:
Old 02-17-2007, 08:56 PM   #5
The one in that pic is probably more for show than anything else.
One thing to note the photo - the side skirts would be better if they incorporated a rear tire air deflector. It looks like it tucks in right before the rear tire, directing the airflow right at the tire
For an aero-minded side skirt, it should not extend any lower than the lowest point of the vehicle. That way you are not increasing your projected area in a cross-wind, but you will keep the crosswind from directly hitting any exposed parts - kinda like an air dam for the side.
GasSavers_BluEyes is offline   Reply With Quote
Old 02-17-2007, 09:19 PM   #6
Peakster's Avatar
Composite Headlamp Conversion
How about headlamps that fit flush with the car's body:
Attachment 212
Vs.
Attachment 213
Do you think there's any real aerodynamic improvement? To tell you the truth, I like the square headlamp style better (in terms of looks).
ID:	185   Click image for larger version
Old 02-18-2007, 04:46 AM   #7
I'd say it's likely one of those "tiny but real" improvements. Partly because it's not a uniform bucket (unlike, say, a hole in the matrix of a vertical grille which you could block from either side for the same effect).
I'll add it to the list.
Old 02-18-2007, 04:48 AM   #8
skewbe's Avatar
...but I read that headlight buckets "pile up" dead air in front of them and the rest flows well so no aero penalty...
That was just some marketing tripe. Of course there is a penalty. Leave all your other windows closed and pop out your windshield, do you think your MPGs will notice?
Standard Disclaimer
Old 02-18-2007, 04:53 AM   #9
skewbe's Avatar
your metro has the same hazy plastic headlight symptom that mine does. It looks a lot better when they are new.
Standard Disclaimer
Old 02-18-2007, 05:06 AM   #10
Tuggin at the surly bonds
Silveredwings's Avatar
I had that symptom on my passat. I wet-sanded them with #400 emery paper, then #600, then Novus #2 (fine) polish and then Novus #1. They were crystal clear. It works on taillights that get foggy too.
edit: use masking tape to protect the paint.
Trying to add a car bw61374 Fuelly Web Support and Community News 1 08-17-2013 07:14 AM
SMS banner. DTMAce Fuelly Web Support and Community News 3 03-08-2010 09:56 PM
elg's Project zpiloto General Fuel Topics 2 03-03-2007 06:47 PM
If you're jealous of Matt, (or have 56k) don't look here. bagpipe goatee General Discussion (Off-Topic) 8 11-15-2005 06:24 PM
