Metro aerodynamics - Page 26 - Fuelly Forums
Old 06-21-2007, 07:08 AM   #251
jwxr7's Avatar
I like it. I hope it works out well for you. Might also keep the interior cooler?
Thanks, And I was thinking that too.
Originally Posted by MetroMPG View Post
I wasn't sure which side was the good side .
Me either . There probably is no good side.
I also need to say that I love the packing tape I've been using, valuable for aero mods.
Old 06-21-2007, 07:42 AM   #252
I wish I had more to contribute to this thread. I've got a backlog of aero mods I want to do to the Fireflea, but the ForkenSwift is getting all my attention & time so far this summer.
EDIT: if I were driving the 'flea more, I'd have added incentive to be working on it, but the beater bike has pretty much displaced it. The thought of selling it has crossed my mind. (But I probably won't... not yet anyway.)
Old 06-21-2007, 07:50 AM   #253
jwxr7's Avatar
That would be a sad day , but if you do and you want to put the original tranny back in, I would love to get a taller trans to put in my car . Actually I should call around to the local junkyards and see if they have a 1.3l 5spd geo variant I could get a trans out of. That could be my next big mod .
Old 06-21-2007, 07:59 AM   #254
It's funny: I know where there's another 1.3L 5-spd Swift hb rusting away in someone's yard not 2 km from where I'm sitting. I ride past it regularly. While searching for a donor ForkenSwift car, I stopped in twice to see if he'd sell it, but the reality of its value (ie. parts/scrap) hasn't yet penetrated his brain .
Old 06-27-2007, 04:13 AM   #255
jwxr7's Avatar
Just trying to optimize the kammback.
Okay, I got my hands on a couple types of angle finders. One uses straight edges and a protactor (kinda small) the other is a magntic base pointer that uses gravity to align the pointer to a circular degree scale. When you talk about the angle of the kammback panels, what is it with respect to? Like for the top piece, Is it to a level horizontal plane , or to the panel that it is coming off of (roof line)? Trouble is, the roof line is curved so it's hard to know the angle exactly unless you know where you should be trying to measure it . I feel I could be reducing the rear drag area more but don't want to go too far. A tuft test may be in order if I can round up helpers to do it .
Old 06-27-2007, 04:31 AM   #256
Yeah, this is tricky.
Any references I make are measured from the horizontal, and for angles which are actually curves, I try to estimate the average angle along the curve.
Old 06-27-2007, 04:41 AM   #257
jwxr7's Avatar
Okay, that helps . I just increased the angle of my top flap last night. From the horizontal it is about 12 -13 degrees. I am going to tape some string to the kammback before I leave work. The coroplast I am using is somewhat transparent so i will be able to see thru looking in my mirror to what is happening .
Old 06-29-2007, 04:06 AM   #258
jwxr7's Avatar
I did a solo tuft test on my way home from work. It looks like I have attatched flow all over the kammback (at least what I could see from the inside while driving). While I was at it, I tufted around my windshield wiper area. The deflector cover I made for my ds wiper is acting like a cowl. The tufts were being pulled down and under the cover. I removed it and think I may be better off without it. There didn't seem to be too much turbulence after the wiper (at least the tufts were pointing up the windshield). So a trade off, is it better to have a low pressure zone behind a small cowl or a smaller high pressure zone in front of the wiper parts?
Oh, and I put tufts on the back window too. They were motionless, just hanging by gravity. I also have good flow over my side window were my mirrors used to be . I may try it again with thinner tufts because the ones I used were pretty husky. Then I may get a more sensitive system going .
Is your vehicle set correctly? DTMAce General Fuel Topics 1 03-17-2010 05:21 AM
fuel economy question Creamycaesar General Fuel Topics 19 02-08-2010 07:37 AM
p07 ECU $15 Matt Timion For Sale 4 08-27-2006 11:25 AM
I will be bike riding across Iowa kickflipjr People Powered 11 08-02-2006 03:22 PM
Some glue that won't melt when it gets hot? SVOboy General Maintenance and Repair 16 08-01-2006 07:15 AM
