Electric conversion: Project ForkenSwiift - Page 65 - Fuelly Forums
Old 06-18-2007, 03:50 AM   #641
Moderator
GasSavers_DaX's Avatar
Originally Posted by MetroMPG View Post
Tinkered a little more with the front racks on Saturday. Still nothing photo-worthy though. This week. Maybe I'll slack off tomorrow afternoon and do some more work on it.
I've been eBaying for a proper welding mask too, since there's going to be a need for that at this stage of the game.
Are you looking for an autodark? If you're going to do any more welding after this project, I'd recommend getting a good one. I bought a cheapie first time around and after it went "light" on me during welding for about the 10th time, I sucked it up and bought a Miller Elite - haven't been flashed since - even on very low current settings.
I still have my cheapie eBay autodark in my shop - I pull it out when someone else wants to observe me welding.
Old 06-18-2007, 04:00 AM   #642
Tuggin at the surly bonds
Silveredwings's Avatar
Anybody know if the harbor-freight ones are any good?
Old 06-18-2007, 05:57 AM   #643
Yep, I was looking for an autodark kind. I was planning on snatching up one like this: http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=020
Old 06-18-2007, 06:09 AM   #644
Moderator
For what you're doing, I guess that will work. That's like my eBay helmet. The problem with these helmets is that the light sensor is small and there is only one - what happens is that while you're welding, if your hand or something is blocking the light from getting to this sensor, it will flash clear. This also happens on low amp settings (which you probably won't use unless you're tigging something thin). My Miller helmet has four sensors and a larger viewing window. It is also capable of staying dark for inverter machine arcs, and will stay dark down to 5 amps of current. Another difference in the helmets is the material - my eBay one is very thick, stiff plastic and gets uncomfortable rather quickly. My Miller helmet is made of a thinner, softer plastic which is more flexible and comfortable.
In the light of this being a budget project and the small amount of welding you're doing, I think you will be fine with the eBay unit. If you think you'll be welding a lot more in the future, get a good helmet.
Old 06-18-2007, 06:41 AM   #645
Thanks - that's good info. Amount of welding will probably be minimal, and higher current as you guessed. So I'll see if I can snag one of these and I'll report back about how it turns out.
Old 06-18-2007, 06:20 PM   #646
It was welding day in ForkenSwiftland! Fun, fun.
Old 06-18-2007, 09:21 PM   #647
Welding helmets
Forgive my ignorace, but what's wrong with ye olde fashioned welding helmet?
I got one for $10AU and it's great. I even used the crummy plastic lens for a while but it was a bit light so I replaced it with a glass lens and spatterguard (about another $10AU) which was even better.
Then again, I may be a retro grouch/tightarse since I also use an arc (stick if you prefer) welder
Nice to see your build is coming along well anyway.
**edit**
On closer inspection that first photo was of a crappy helmet without a flip up lens.
lemmiwinks is offline   Reply With Quote
Old 06-19-2007, 12:38 AM   #648
Hello all I am a newb and started reading this thread... Wowo its long.. anyway what are the current specs on this car how fast will it go and how far?
Has there been any talk on adding solar panels or a diesel generator for extended range? Or maybe even a small gas motor for high way speeds?
GasSavers_RickyD is offline   Reply With Quote
Old 06-20-2007, 07:08 PM   #649
Discovered another Suzukiclone conversion today, just down the highway in Toronto:
http://www.austinev.org/evalbum/1219
Looks like they did a 4wd conversion while they were at it!
Old 06-20-2007, 07:17 PM   #650
With the hood closed, there's about 1.5 in between the tip of the forward battery posts & the hood.
I think I'd make sure to have electrical insulating materials on the underside of the hood just in case something shifted and altered that clearance.
As always, great work.
Combined totals of all my vehicles? nizationpcs Fuelly Web Support and Community News 0 03-30-2009 06:41 AM
Converting numeric to current tire sizes. omgwtfbyobbq General Maintenance and Repair 5 06-01-2007 04:51 AM
Prius. First Impressions zpiloto General Fuel Topics 17 09-03-2006 10:49 PM
