Electric conversion: Project ForkenSwiift - Page 71 - Fuelly Forums
Old 09-07-2007, 12:09 PM   #701
OK, so directly flattening / soldering / flattening the cable end
Old 09-07-2007, 03:08 PM   #702
Send a message via ICQ to GasSavers_BigMouse Send a message via AIM to GasSavers_BigMouse Send a message via MSN to GasSavers_BigMouse Send a message via Yahoo to GasSavers_BigMouse
Originally Posted by MetroMPG View Post
OK, so directly flattening / soldering / flattening the cable end itself is the ticket. Weekend project - I'll have the FS operational again shortly (pun not intended).
Those cables look used. Where'd you get them? 20ft of 2/0 AWG welding cable is expensive :-(
GasSavers_BigMouse is offline   Reply With Quote
Old 09-07-2007, 06:22 PM   #703
Do you know offhand how people generally route cables from one end of the vehicle to the other? I'm assuming underneath the car, in the exhaust/transmission tunnel. I was thinking we could get some plastic conduit and run it inside that for protection from the elements.
I'm not sure what the common method is, but I was thinking of doing the conduit method as well. Seems to be a safe way to pull it off. Safer than running through the car at least. I look forward to seeing the pics of your lug-less cable ends.
Old 09-08-2007, 10:01 AM   #704
Rear flattened/soldered/flattened batt interconnects turned out well and are installed. Picked up 2 lengths of plastic 1 inch ID conduit as well. Continuing to plug away this afternoon...
Old 09-08-2007, 10:27 AM   #705
trebuchet03's Avatar
Conduit is probably better than what I was going to suggest
Large garden hose It's flexible and you know it's water tight
11/12
Old 09-09-2007, 05:32 PM   #706
Ooooh. Garden hose is a good idea if you're using 2/0 gauge. It would be a little more saggy than the conduit, but you could work around that.
Old 09-09-2007, 05:39 PM   #707
skewbe's Avatar
Duh, I was worried about the exhaust pipe when you mentioned conduit under the car. LOL
Cool Cables, lets hope they don't melt
Standard Disclaimer
Old 09-09-2007, 05:48 PM   #708
I know... I kept firing up the torches at the back of the car this afternoon, and every time I did I thought, "wait! gas fumes!"
I don't think the cables will melt. Unless I really misunderstand what's going on, the 4/0 is WAAY overkill. The internal wiring inside the motor itself is more like 2/0 size. That's what I'm more concerned about melting...
In further "misunderstanding what's going on" news, today was the first time since the start of the project I mistakenly shorted out pack voltage. Freshly charged, too. !!!ZORCH!!! I vapourized the end of a 2/0 lug. :O
Old 09-09-2007, 09:59 PM   #709
Thumbs up
That soldered cable end that turns into a lug is fantastic! Really, really good. Could you post up a tutorial so we don't all have to go through the learning curve please?
lemmiwinks is offline   Reply With Quote
Old 09-10-2007, 06:49 AM   #710
Originally Posted by lemmiwinks View Post
(...) Could you post up a tutorial so we don't all have to go through the learning curve please?
I second this request!
Combined totals of all my vehicles? nizationpcs Fuelly Web Support and Community News 0 03-30-2009 06:41 AM
Converting numeric to current tire sizes. omgwtfbyobbq General Maintenance and Repair 5 06-01-2007 04:51 AM
Prius. First Impressions zpiloto General Fuel Topics 17 09-03-2006 10:49 PM
