I got an EV! - Fuelly Forums
Old 11-15-2007, 07:57 PM   #1
lovemysan's Avatar
I got an EV!
http://www.legioncontrols.com/detr500wastr.html
not the actual pic but its the same.
No its not a car. But the price was right, I bartered an 1 1/2 of work. Its got a 500w 24volt motor, controller, throttle, lights, its fully functional. It will go about 10mph. My yard sale batteries died after traveling 30ft, I'm going to try charging them in the morning. I intend to rob the parts off of it for my bike conversion. I'm having trouble with it throwing the chain.
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 11-15-2007, 08:27 PM   #2
skewbe's Avatar
Cool, an electric office chair with a wheelie bar
Standard Disclaimer
Old 11-15-2007, 08:33 PM   #3
GasSavers_Red's Avatar
Kewl
Old 11-16-2007, 06:18 AM   #4
Gonna put some skirts on that?
GasSavers_landon is offline   Reply With Quote
Old 11-16-2007, 08:29 AM   #5
lovemysan's Avatar
Maybe!
Question. What voltage should a 24volt pack be showing when fully charged?
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 11-16-2007, 08:35 AM   #6
trebuchet03's Avatar
Originally Posted by lovemysan View Post
Maybe!
My worn out and abused pack reads 26.7V --- ~13.3ish volts per battery (2) These are two small gel cells
11/12
Old 11-16-2007, 08:40 AM   #7
lovemysan's Avatar
I had to do quite a lot of wiring repair to get it going. The PO had it worked on at batteries america. When I fixed the charging circuit this morning the polarity was reversed. All the colors were matched correctly. I made the mistake of not testing the output before hooking everything up. When I hit the charge switch the charger sizzled and started smoking. The funny thing is that apparently the charger was unhurt. I had the controller unplugged so everything should be fine. Its charging now I should be able to test drive after lunch.
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 11-16-2007, 08:42 AM   #8
lovemysan's Avatar
What should be the minimum voltage before damage to the cells? The batteries were weak before I started. I was getting 24.3volts after a spotty charging and 2 month sit on the shelf.
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 11-16-2007, 07:06 PM   #9
lovemysan's Avatar
I tested it out today. It really will go 8-10mph. Its got a range of about 5 minutes at full throttle. I'm going to balance the pack tomorrow.
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 11-16-2007, 07:14 PM   #10
skewbe's Avatar
is it one wheel drive?
Standard Disclaimer
ebay ScanGauge 1 MetroMPG Hypermiling 1 06-26-2007 07:16 PM
Cooling fan mpg DRAG....?? ZugyNA General Fuel Topics 4 06-12-2007 12:29 PM
Engine compartment airflow roadyj General Fuel Topics 4 06-02-2007 08:05 AM
Jet Beetle diamondlarry General Fuel Topics 0 03-02-2006 02:49 PM
Leaning fuel mixture and effect on engine temp Flatland2D General Fuel Topics 18 12-16-2005 09:11 PM
