5 Failed Logins requires captcha - Fuelly Forums
Old 10-17-2011, 02:26 AM   #1
I know that you have this implemented for security reasons, however I think your implementation may be flawed unless this is how you expect it to work.
Here's how I see it working
If you fail to login 5 times the site should require you to login with a captcha, however once you successfully login with the captcha it should not require you to use the captcha ever time you login that day. I feel it should reset this.
The way it works on the site.
If you fail 5 login attempts it will require you to fill in a captcha EVERY-TIME you login to the site even after successful logins with the captcha.
Is this how you expect it to work?
jcrawford27 is offline   Reply With Quote
Old 10-17-2011, 02:30 AM   #2
pb
If you fail five login attempts you'll need to fill in a captcha when you log in for 24 hours. It should reset after that.
We know it's a hassle to fill out a captcha, but we don't want anyone to be able to automate requesting login info. I know you're working on a site scraper so you are sending automated requests to Fuelly pretty regularly. For people using the site normally I don't think this is a problem.
