Fully Not Recognizing Initial Odometer Reading - Fuelly Forums
Old 01-15-2020, 03:15 PM   #1
Can't figure out why Fuelly isn't recognizing my fill-up for my new car; My Outback. I created an initial fill-up and included staring odometer, but Fuelly doesn't input that initial odometer reading on the second fill-up. How do I fix this.
LarryJ is offline   Reply With Quote
Old 01-15-2020, 11:04 PM   #2
It doesn't. It calculates the second input using the odometer from the first but doesn't display it.
Old 01-15-2020, 11:06 PM   #3
I glanced at your dashboard. Are you sure you input miles for your second fuel up as I can't see any? Fuelly cannot work out the fuel used over a certain distance with out the miles.
Old 01-16-2020, 02:23 PM   #4
I'm tracking by inputting odometer reading, not by inputting miles. Fuelly isn't recognizing (or showing) the initial odometer reading I entered after topping off from the dealership. Miles travelled isn't being calcuated because Fuelly isn't seeing the first odometer reading. First odometer reading was 39658. Second full fill-up was 40052, or so.
Old 01-16-2020, 11:08 PM   #5
I am unfamiliar with this method of tracking. Have you tried editing the fuel up and seeing if "partial fuel up" was accidentally checked? And have you tried deleting it and re-entering just incase you entered the odometer reading wrong (this has happened with other users in the past).
Old 01-17-2020, 12:49 AM   #6
I'm with Draigflag on that. If you use the total odometer reading Fuelly works out and displays the trip miles anyway. As you have only two fill ups input I would delete them and input then again. Make sure the first is an initial fill and the second IS NOT a partial top up.
Old 01-18-2020, 04:17 PM   #7
Please explain how to do this. There's absolutely no botton or box to check to tell fuelly that one fillip is an initial fill-up vs a normal fuel-up. I have NOT checked "partial fill-up".
I've tracked mileage on three vehicles on fully, one of them by odometer readings, don't recall having such an issue. Fuelly needs to make it more user friendly.
Old 01-19-2020, 12:11 AM   #8
I believe you only get that when you first add a vehicle to your garage.
