Help with this recording process please - Fuelly Forums
Old 03-21-2015, 06:52 PM   #1
Country: Australia
Hi,
I'm looking for some suggestions how to best capture the fuel data given the process I use.
Each fuel visit I take 150L and share as required between 2 vehicles.
Unlike the typical process of re-fuelling a near empty tank long with the resetting of the trip meter. My method does not accommodate this simplicity.
How can I use Fuelly to effectively capture consumption and costs with my above scenario? For both vehicles.
Thanks in advance.
GLOpro is offline   Reply With Quote
Old 03-23-2015, 02:17 PM   #2
As long as you know the amount of fuel going into each vehicle, and the cost of it, the averages will wash out correctly anyway. I'd say do NOT select the "Partial fuel up option" -all you need is miles per consumption, not the reletive fullness of your given fuel tank.
Dozenspeed is offline   Reply With Quote
Old 03-23-2015, 04:49 PM   #3
How do you fill the vehicles?
Portable gas cans; just count the number of full cans added and estimate the last.
Hand pump; measure the volume dispensed with each pump or crank, then count the cranks.
Powered pump; time how long it takes to fill a known volume, then time the fills.
