How to record more than one fuel in same vehicle - Fuelly Forums
Old 08-16-2017, 04:43 AM   #1
To prevent the engine light, I have to mix 1/2 88 with 85, how would I record this.
wallyma is offline   Reply With Quote
Old 08-16-2017, 04:55 AM   #2
You can add the two volumes together, record that, and make a note of the average octane. It will be 87.5 with equal volumes of 88 and 85.
Old 08-16-2017, 06:50 PM   #3
I just put the total fuel. The total cost. Fuelly comes up with the cost per gallon for me.
That average octane is 86.5 not 87.5.... Me thinks somebody did a typo.
I hope you're not mixing ethanol with non ethanol. When I played around with octanes. I stuck with no ethanol only. Found smaller amounts of premium worked better. Then changed brands and tried 85 no ethanol only. Found it worked great. Either way.... stay away from ethanol.
14Corolla is offline   Reply With Quote
Old 09-29-2017, 08:23 AM   #4
You should have your car serviced. There is a problem with your engine or exhaust system. Fixing it early will be cheaper than waiting until it becomes catastrophic. Mixing gas is an insane temporary solution. Just get the car fixed. It might just be an Oxygen sensor, if you are lucky.
rolleikin is offline   Reply With Quote
