What is partially fuel up and Missed fuel up? - Fuelly Forums
Old 08-05-2015, 09:58 AM   #1
Country: Italy
Hi guys! could someone explain me what the partially fuel up option is and the missed fuel up one?
I don't do my tank full, so have I to choose always the partially fuel up option when I add a fuel up?
Tony83 is offline   Reply With Quote
Old 08-05-2015, 10:28 AM   #2
Fuelly can only calculate your economy if you go from full, to empty, and then full again. You cannot calculate your economy unless you do this, every fuel up will be partial the way you do it.
A missed fuel up is if you are tracking via odometer reading only.
Old 08-05-2015, 10:46 AM   #3
Looking at your figures I think you may have added most of your fuel ups incorrect, some are as low as 26 MPG, and other are 70 MPG, that's a huge difference.
Old 08-05-2015, 11:34 AM   #4
Country: Italy
so I can't use this software because I don't go from full to empty.
Thanks for your reply
Old 08-05-2015, 11:59 AM   #5
RobertV's Avatar
You don't necessarily HAVE to go to empty. That's just ideal.
You just need to fill your tank (top it off) with every visit to the pump.
Even if you fillup when your gauge reads half-tank, as long as you pump until it's full (usually when the nozzle clicks/stops) then you're all set.
A partial fillup is if you only put in say "$5 worth" regardless of the amount of fuel you actually pumped.
So if you're at half a tank, visit the fuel station and only pump enough fuel to get you to the 3/4 line, then you have NOT filled-up, and must mark it as a Partial Fill.
Old 08-05-2015, 12:12 PM   #6
Country: Italy
So should I modify all my fuel up records in partially fuel up because I have never filled the tank fully?
Old 08-05-2015, 12:34 PM   #7
RobertV's Avatar
If you don't fill the tank completely, then yes, you made a Partial fill.
Old 08-05-2015, 12:46 PM   #8
This same issue comes up time and time again on fuelly. I've pointed out numerous times that in many parts of the World, high fuel prices mean most people rarely fill thier tanks ever. It's a great programme for some people, but doesn't suit everyone!
Old 08-05-2015, 12:53 PM   #9
Country: Italy
Thanks a lot for your replies. I'll try to use the software in the correct way
Old 08-05-2015, 01:13 PM   #10
RobertV's Avatar
So what would you suggest as an alternative?
