10-27-2007, 12:48 PM
i'yme not qwite shir what he's askin
no matter what he's gotta jack the car up, put a blockin there somehow to keep the tire from rubbing, and get a tow home. then, replace what's busted. what r we sposta do beyond that?
hey clencher, that cars is older than me!
od, good luck! is that a daily driver? or was it?
10-27-2007, 03:47 PM
this is what broke for all that i can tell im gunna have 2 days off so im gunn pull the shocks off and hopefully the swaybar/rocker arms off to make sure there not broke but this is the only piece that broke off.
10-27-2007, 05:16 PM
Boy, that is strange. I'd have thought that the spring clip plate (see the left side of your illustration) would hold everything together enough.
10-28-2007, 04:04 AM
First off. SWEEETTTTTT car!!!!!
Next... Ya, anything brakes there and that wheel is moving. My guess is you might have bent the spring also. I cant see the pic of what broke, but I would check it ALL out real well. Its a old car, and if one part broke, others may be close behind it. Also check to make sure the ujoints did not bind up when it broke.
Paul B
10-28-2007, 09:09 AM
10-28-2007, 09:37 AM
ooh, looks like your differential blew up. (is there fluid in there at all, most people forget to check that). have fun swapping in a whole new rearend.
10-28-2007, 11:16 AM
talked with my friends dad whos a mechanic and he saidit was just the bearings gave looseand the hub forge to the shaft.
10-28-2007, 05:54 PM
#19
the bearings on the rear passanger side were torn to up and half the balls were flat, so i cleaned out the area where the axel/shaft came out of looked at the shaft the bearings did no dmg to the shaft or grooves/threading. 3 knocks got the hub/brake drum with a rubber hammer got it away from the axel/shaft with ease. Ordered the part seal + ball bering and low and behold i had the rarest ball bearing of them all set me back $80 for one bearing, luckly my friends brother is a mechanic and he is showing/making me do it for free.
10-28-2007, 07:59 PM
#20
haha thats good. least u can still get parts
