Found 2 CRX HF... have at em! - Fuelly Forums
Go Back   Fuelly Forums > Marketplace | Buy, Sell, Trade > For Sale
Closed Thread
Old 07-22-2009, 06:12 AM   #1
http://providence.craigslist.org/cto/1265490574.html
and
http://capecod.craigslist.org/cto/1279619930.html
I'm looking for one for myself (Kinda) but I'm still waffeling between the CRX HF and a Civic VX... as well as the cash for a project =)
Good Luck!
ssalesky is offline
Old 07-22-2009, 10:09 AM   #2
vxdude's Avatar
Send a message via Yahoo to vxdude
if i had to redo it all over again i would choose the hf. Parts for the hf are way cheaper than the vx. No lean burn and no heated O2 sensor that cost 300$
vxdude is offline
Old 07-23-2009, 10:07 PM   #3
The down side to the HF is that it can only hold two peoples. I have a HF myself and there's certain time when I just wish it can hold a few more peoples back there LOL. Your solution to the expensive VX problem is very easy, all you have to do is just buy the CA ECU and a regular 4 wires oxygen sensor. The VX run much beter in the CA mode too because it doesn't have lean burn.
GasSavers_viperguy is offline
Old 07-24-2009, 11:05 PM   #4
panamacolin's Avatar
without lean burn you might as well buy a cx same tranny as a vx...lean burn is where its at.
panamacolin is offline
Old 07-27-2009, 08:33 PM   #5
Well it depends because the VX has 20 more horse than the cx.
Old 08-13-2009, 08:33 AM   #6
And a tach, and them sweeet alloys. VX FTMFW.
roadsterbum is offline
Old 08-21-2009, 03:48 PM   #7
imzjustplayin's Avatar
Not to mention probably has more low end torque because below the Vtec threshold it can be more optimized for that RPM range while on the CX, it has to have a little bit of high end a little bit of low end. In a sense, the Vtec-E on the VX gives it a huge advantage over the CX. If the VX's VTEC didn't work, running in the 12 valve mode, it'd probably have the same HP as the CRX HF.
imzjustplayin is offline
Closed Thread
how much psi can i pump safely? civic94 General Fuel Topics 13 11-07-2007 01:14 PM
Interesting article about aerodynamics McPatrick General Fuel Topics 0 06-23-2007 06:11 PM
VX Head Question GasSavers_scostanz General Maintenance and Repair 8 02-17-2007 03:27 AM
