How Do I Enter Tire Pressure? - Fuelly Forums
Old 07-30-2015, 04:59 AM   #1
My motorcycle specs a different tire pressure for the front and for the rear.
How exactly am I supposed to input this?
I don't know of any vehicle that only has 1 tire (unicycles are not on the road).
So, is this supposed to be a fixed value that never changes? I mean, if I check my tire pressure readings while filling up and enter that data here, there is little chance that all tires are going to have the same pressure.
If I fill my tires so that they then all have the same pressure, then what is the point of recording it?
jp2code is offline   Reply With Quote
Old 07-30-2015, 05:14 AM   #2
RobertV's Avatar
Looking into this now. Thanks for bringing it to our attention.
Old 07-30-2015, 05:25 AM   #3
RobertV's Avatar
This is a work in progress...
In the meantime, some of our beta app testers have mentioned using a decimal as the "separator". In your case "36.38".
Old 07-30-2015, 05:31 AM   #4
Sounds good. Thanks for the update.
I gather this is a new feature (it wasn't there at my last fill-up recording), and that the on-screen guidance/help text (textbox onblur() event & description line below) will follow after it is out of Beta.
Old 08-14-2015, 04:40 PM   #5
Was just searching this and found this thread. Guys with trucks, like myself, often run different tire pressures front and rear for towing and hauling. Glad to see it is being addressed. Thanks!
Gadgetguru is offline   Reply With Quote
Old 09-18-2015, 09:54 AM   #6
I take my tire pressure readings directly from my dashboard display and it gives readings for each individual tire (four readings).
How would I enter all four tire readings? 35.36.34.36 isn't a numeric value. Neither is 35 36 34 36.
I had to enter it as 35363436, which is not intuitive at all. Didn't the developers at Fuelly solicit input from drivers? How did this get released?
SoCalDude is offline   Reply With Quote
Tags
jp2code
