Originally Posted by Bill in Houston
To me, when you try to calibrate a Scangauge with fill data, you can make yourself crazy if you adjust every time. I'd get it close, and then leave it. Over several more fills you might identify a certain bias, and correct for that. But messing with the calibration every tank doesn't make sense to me.
Makes sense to me as well. Adjusting often takes you down the path of over control. You need to collect enough fill up data points to get a good average.
Try to use the same station and pump every time, even the same time of day due to temp changes. All pumps are accurate enough but due to the angles of the parking lots and different click off pressure theres going to variability in your results if you don't use the same pumps.
