To draft or slow down? - Page 12 - Fuelly Forums
Old 05-08-2008, 05:23 AM   #111
palemelanesian's Avatar
I saw a study done with 2 computer-controlled semi trucks. At a 10-ft following distance, the trailing truck got a 15% boost in mileage, and the leading truck got a 10% boost. At no point did the leading truck actually lose mileage.
And as I said earlier on, you get a benefit even at a legal, safe 3-second following distance. 70mph distant-drafting beats 65mph driving solo.
Update: I got the numbers wrong, but the concept is accurate. Here is the study: http://gcep.stanford.edu/pdfs/ChEHeX...0_11_trans.pdf
Old 05-08-2008, 06:45 AM   #112
Snax's Avatar
I think the problem with benefiting the truck is that the following vehicle has to be really close, otherwise the effect drops off very quickly, and is likely nil at a distance that a normal person might consider safe to follow at.
LiberalImage.com
I think, therefore I doubt.
Old 05-08-2008, 06:50 AM   #113
Nil is acceptable. The question was whether it causes the puller any detriment, which it does not.
Old 05-08-2008, 07:35 AM   #114
Wow.... I haven't checked the thread in a few days and there are million posts!
I supposed I had a good first question!
Anyways, I updated my mileage log with my tests between drafting and slowing down. I managed to get a couple MPG better by slowing down. I think I will do another test to see if the results are confirmed.
racertim is offline   Reply With Quote
Old 05-08-2008, 07:39 AM   #115
This is a test I did in my minivan.
Old 05-08-2008, 07:45 AM   #116
Your minivan has different characteristics than my civic. I noticed a drop in economy and was following much closer than 3 sec.
Old 05-08-2008, 07:52 AM   #117
The Civic has TERRIBLE highway gearing. But I've done some great numbers using Pulse&Glide combined with a 2-3 sec draft - upper 50's mpg at 70mph average. The aerodynamic benefit is still there, it's just that the high gearing masks it.
Old 05-08-2008, 07:58 AM   #118
What do you recommend that I try differently then? I was cruising steady behind the trucks at 1 sec at 70mph on average.
Old 05-08-2008, 08:00 AM   #119
Hateful's Avatar
Send a message via AIM to Hateful
I do the same with my Cavalier with good results.The pulse and glide seems more of a benefit for my MPG's,but if I can get both I will.
Hateful is offline   Reply With Quote
Old 05-08-2008, 08:04 AM   #120
I suggest you work on Pulse & Glide. Running the RPM that high is a KILLER to mileage. Pulse & Glide is a good way to overcome that. I've run that same highway trip several times.
57 mpg - 70mph drafting P&G
43 mpg - 65mph cruise-control
75mpg - 50-60mph P&G
The Drive Smart Challenge mathowie General Fuel Topics 0 08-15-2008 08:55 AM
Transmission Question Dave1215 General Maintenance and Repair 12 05-13-2007 09:39 PM
Cardboard box + duct tape = LxMike Aerodynamics 18 11-18-2006 10:53 AM
Tire / Axle Ratio Calculators ... cfg83 General Maintenance and Repair 1 10-06-2006 04:16 PM
Happy Holidays everyone! Matt Timion General Discussion (Off-Topic) 10 12-29-2005 11:07 AM
