v3 app crashes every time - Fuelly Forums
Old 09-10-2015, 10:11 AM   #1
Was this app tested on IPhone 4 (ios 7.1.2)? It won't load and simply crashes on the start screen. I've tried uninstalling & reinstalling the app and it still crashes.
Works fine on my wife's iphone 6.
-Andrew
There are 10 types of people in this world, those who read binary and those who don't
>> anjpvideo - HowTos and more! <<
anjp is offline   Reply With Quote
Old 09-10-2015, 10:50 AM   #2
RobertV's Avatar
Does it let you login at all?
If it does let you login, is it crashing as it's attempting to sync your data?
Old 09-10-2015, 11:08 AM   #3
The first time it loaded up I was able to enter my credentials and then it hung on the data sync. Now it just crashes immediately.
I uninstall/reinstall and same things happen.
Old 09-10-2015, 12:12 PM   #4
RobertV's Avatar
Sounds like a memory (or lack thereof) issue causing the crash. Especially since you can login fine on your wife's device.
Here's some tips you can try to speed up your device/free up some RAM- Top 5 tips to speed up an iPhone 4 or iPhone 4s running iOS 7 | iMore
Alternatively, I would recommend using the mobile web site to log fuel ups: m.fuelly.com
Old 09-10-2015, 12:31 PM   #5
I have the same thing, got to the log on, then it always crashes. I have a iphone 4 too on 7.1.2.
robbieracer1 is offline   Reply With Quote
Old 09-10-2015, 12:37 PM   #6
I did these recommendations and it still crashes every time.
Old 09-10-2015, 02:30 PM   #7
RobertV's Avatar
Sadly, it seems the verdict is the iPhone 4 has a problem with running out of RAM when running memory intensive apps, and therefore is what's causing the crash.
I'll talk with our developer to see if there's any more trimming we can do, but I know we spent over 3 weeks trimming down the memory usage significantly (and as much as we could at the time). Therefore, I'm not sure what else can be done to help those few of you with the iPhone 4.
Old 09-10-2015, 04:10 PM   #8
Mine is doing the same thing, but I have a 5s running ios 7.1.2. Tried all the rebooting. Delete and reinstall. Nothing works.
derek77 is offline   Reply With Quote
Old 09-10-2015, 06:27 PM   #9
It could be a RAM issue. But it does it on a fresh boot also... so if it is truly a memory-related crash, the program must be using a lot.
Was v3 ever tested on an iphone 4 or an ios 7 device?
Old 09-10-2015, 06:54 PM   #10
RobertV's Avatar
This is strange. The 5S shouldn't be running out of memory. I think you're the only one so far that's reporting a crash. Are you able to login at all? When is the app crashing?
Honestly, there are only 2 reasons for a crash-
Running out of memory or an OS-specific issue.
iOS7 isn't much different from 8 in regards to the stuff we're using.
The fact that you can login to your account/sync your data on your wife's device means there's nothing in the data that's triggering the crash.
This leaves us with ultimately, lack of memory on your specific device.
Yes; there is no reason for the app not to work on your specific device/iOS version other than a memory issue.
Keep in mind our testing devices aren't necessarily our primary phone/device. So they aren't going to be filled with many apps, pictures/media, etc and may have just enough RAM to complete the sync process while yours may not.
Tags
crashes, iphone 4
