Engine fuel specification - gasoline missing - Fuelly Forums
Old 03-28-2018, 10:22 AM   #1
Country: Italy
Hi, as per object, I encounter a small trouble with aCar app.
I defined all I need directly on android terminal, by using your fantastic app.
Then I sincronized my data with fuelly.com.... is this a mistake?
Defining vehicles in the app, give problem during engine fuel specification, when the fuel is gasoline. In the drop down list gasoline is not available!
So i left two vehicles with empty engine specification.
Another (diesel) car gives not problems, because "diesel" exists in drop down list.
Can you help me, or explain me ... in case of my mistake?
Thanks a lot
Regards
Luiss64
Luiss64 is offline   Reply With Quote
Old 04-05-2018, 09:33 PM   #2
Country: Italy
Exclamation Fuel Type dropdown screenshot
To better explain the meaningful, I enclose a screenshot about Fuel Type dropdown.
GASOLINE (or petrol?... "benzina" in italian) is missing - please look the picture.
Is this an aCar app limitation, and could be improved?
Or is it a source database (external from aCar and Fuelly) limitation, and couldn't be modified?
Thanks a lot
Old 04-05-2018, 09:52 PM   #3
GAS is short for Gasoline, or petrol for the UK and benzina in Italy. LPG is gas gas!
Old 04-06-2018, 04:53 AM   #4
Country: Italy
Incredible! I had not really imagined it!
and it seemed strange to me to be the only one to have the problem of gasoline .....
I can not find the words.
thank you very much @ JockoT
Old 04-21-2018, 09:43 AM   #5
You weren't the only one. When the switch from aCar to Fuelly occurred, I didn't realize my fuel type was defaulted to gas (gas). I finally noticed no 87 Octane choice and switched to gasoline.
seasnake is offline   Reply With Quote
Tags
engine type, gasoline
