Gas Tracker 2.0.4 Odometer issue - Fuelly Forums
Android Users - Coming Soon! - Migrating from aCar 4.8 to 5.0
Old 08-28-2014, 01:28 AM   #1
Country: South Africa
Hi
I'm on the latest iOS running on a 4s.
When trying to enter an odo reading during a fuel up and or during a note
for a vehicle the odo does not accept more than 4 digits. During the note taking it only
saves the very first digit.
I saw this was an error on previous versions but seems to still be happening.
Any suggestions/help.
Thanks and regards
DjFloYd is offline   Reply With Quote
Old 08-28-2014, 05:51 AM   #2
RobertV's Avatar
Which vehicle and what is the Odometer you're trying to input?
Old 08-28-2014, 06:04 AM   #3
I'm trying to put in 12380Km on my KTM690 for the fuel up.
I'm also trying to put in 8330Km in a note for the same vehicle.
Old 08-28-2014, 07:32 AM   #4
RobertV's Avatar
http://www.fuelly.com/car/ktm/690_en...oYd/312953/log
The first fill-up took.
Just tested adding a note on my end and didn't run into any issues. Please try again.
Does it throw an error message or anything?
Can you post a screenshot?
Old 08-28-2014, 08:03 AM   #5
Country: Poland
after logging in to fuelly,com via Gas Tracker app on iphone, it shows wrong data...
- cannot ad odometer data [four digits], and
- when old fuellup is it shows no odometer data...
https://www.dropbox.com/s/hyqnu656tz...2011.00.01.png
MrGlub is offline   Reply With Quote
Old 08-28-2014, 08:33 AM   #6
Ok, well after not winning using the app I entered it via the website when I got to the office.
Is that not perhaps what you are seeing?
I think I will delete all the entries and do it from scratch via the app. Will post the results for both the fuel log and the note.
Old 08-28-2014, 09:04 AM   #7
Ok, so I deleted all the entries for the KTM via this website.
Started from scratch with a new fuel entry using the app....
First screen - no entries - https://www.dropbox.com/s/yx0io53e64...%2044.png?dl=0
Second screen - I typed in the info about to save. The odo shows 1 even though I typed in 12380 after 4 digits it just changed to a 1. Also note the total cost of 225.200. This gets changed to 225.12 when I look at the log after entering it. https://www.dropbox.com/s/n4h8o99xom...%2024.png?dl=0
Third screen - saved successfully. https://www.dropbox.com/s/akqk9bisgf...%2028.png?dl=0
Fourth screen - there's the log entry (and it shows on the website using my desktop browser after a refresh). https://www.dropbox.com/s/8b6szdmv1z...%2034.png?dl=0
Fifth screen - Going back into the entry to view it I get this - note the total cost has changed to 225.12 and the cost/lit is blank or NaN and the odo is all zero?!? Not even the 1 is saved. https://www.dropbox.com/s/kiu9828wbb...%2005.png?dl=0
Regarding the note - even though I deleted it on the website it was still listed under notes for the KTM. No way I can find to delete it using the app. Can't edit the note because I get a sync error. Even adding a new note gives the same error as if notes is completely broken now. https://www.dropbox.com/s/dfvwk7jxbo...%2048.png?dl=0
Old 08-28-2014, 09:13 AM   #8
Some more observations - the 1 recorded shown on the fuel log entry is the first digit from the 12380 I tried to enter. If I tried to enter 33800 then it retains the first digit which is 3.
The entry from the app does not contribute to the consumption figures on the website. I entered a second fuel log on the website and the odo was 12 thousand something - this should have given me some unrealistic MPG figure because the first entry was 1 on the odo but it did not. Only after adding a second entry (third in total) via the website did it look at the previous odo reading and give me a MPG value.
Old 09-24-2014, 03:35 AM   #9
Country: Poland
for now, gas tracker is useless app
Old 12-28-2014, 05:51 AM   #10
Hi, any plans to get this sorted in the app? If you can't enter more than 4 digits in odo, no use for the app and have to log into the website.
thwane is offline   Reply With Quote
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
