90 crx hf how can i increase gas mileage? - Fuelly Forums
Old 06-08-2008, 07:14 AM   #1
I just bought a 90 crx hf with 144000 miles on it. still has orig. engine (d15b6) and tranny. the only mods on it is a stage 3 racing clutch dc headers and a flow master exhaust with a 4 inch tip. I would like to make it stock again what do you guys think i should do? thanks
tyler
tbrown4 is offline   Reply With Quote
Old 06-08-2008, 07:25 AM   #2
friz's Avatar
I can't imagine those mods would affect MPG that much.
I used to curse when I got stuck behind you guys on a two lane blacktop. If you can't beat em?
friz is offline   Reply With Quote
Old 06-08-2008, 07:45 AM   #3
Leave the headers and exhaust.. change back to a quiet muffler if you prefer.
Free flowing exhaust will most likely give you a slight mpg boost..
Old 06-08-2008, 08:56 AM   #4
okay thanks. The car also has a cold air intake but it doesnt fit the car. the owner before took it off a lower 90s civic and put it on. you can pull it right off pretty much. is there a cold air intake that would fit for this model? i have looked for some and found a couple but some sites offer them and others dont for the same intake. so i dont know if they really only fit the 1.5l base 90 crx.
Old 06-08-2008, 09:19 AM   #5
Cold air intakes are good for horsepower but generally bad for mileage..
In fact people are doing the exact opposite and making warm or even hot air intakes to increase mileage.
Old 06-08-2008, 09:40 AM   #6
Cold air intakes have been reported to increase mileage, I would assume by reducing intake restriction in badly designed systems. Either way, if you're interested in monkeying around with your intake, might as well give it a free-flowing Warm Air Intake.
Old 06-08-2008, 09:57 AM   #7
okay thanks tons. so change the muffer and get a warm air intake? anything else i could do to the car to increase mileage? I know I want to change out the clutch to a stage 1 cuz you have to get the car to 2k just to get it to move. and it bogs out if i go under that with the stage 3. Im going to try hypermiling i just read up on that.
Old 06-08-2008, 10:04 AM   #8
I also had another ? have any of you guys used that water for fuel thing? does it really work? thanks
tyler
Old 06-08-2008, 10:20 AM   #9
I don't think bogging under 2k rpms is the clutch. Mine used to do that. It is a CA car. I put the Fed ECU in it and that fixed it. I'm not sure if the old ecu was bunk or not though.
With mine it can start out at 1K in first provided I give it very little throttle until it hits 1.5K then it can be floored
FritzR is offline   Reply With Quote
Old 06-08-2008, 10:36 AM   #10
The best part to modify is your driving.
Your clutch could be no good for FE, and a WAI would probably help (though I haven't yet tried one). Be sure to add air to your tires if they're not already at the maximum pressure stamped on their sidewalls (see the tire pressure link in my sig). There's probably other things you can do.
All added up, those modifications won't have anywhere near the effect that changing your driving habits will.
I don't believe in any of the miracle FE products like water for fuel stuff. I may eventually consider a DIY HHO experiment, though.
Current TV spot merckrx General Fuel Topics 1 08-14-2008 06:36 AM
XFi mirror caps? baddog671 General Fuel Topics 4 07-10-2007 02:51 PM
The great news about the EPA's new tests repete86 General Fuel Topics 8 02-07-2007 06:01 AM
