08-09-2007, 02:57 PM
Member
Just remember, don't open your windows all the way. Only a little bit. When you open them fully it creates a lot of turbulence and increases the size of the wake big time. I remember when tuft-testing my VGs when I opened my windows all the tufts of yarn went all wonky because the mass of turbulence the windows created wrapped around the car.
08-11-2007, 08:14 AM
If you are worried about adding hot air via the heater core, you could put a manual shutoff valve on the inlet line from the engine, and ensure that no hot coolant is flowing to the heater core in the summer.
-- Randall
McIntyre's First Law: " Under the right circumstances, anything I tell you may be wrong."
O'Brien's First Corollary to McIntyre's First Law: " I don't know what the right circumstances are, either."
08-11-2007, 09:04 AM
I just leave the knob turned all the way to cold...
08-11-2007, 09:20 AM
Me too...luckily, my car has a manual button for the compressor, so I just turn the climate control all the way down, and if it gets cool enough, I can just turn the compressor off until I want it.
-- Randall
08-11-2007, 02:13 PM
Mmm-hmm. Me too.
08-11-2007, 09:24 PM
Run AC full cold on recirc if you really need it, and turn AC part off/on manually leaving fan on 3rd position.
AC ruins gas mileage
08-11-2007, 10:43 PM
Or never use it and you WILL get used to it eventually
08-12-2007, 01:07 PM
Every water-cooled car I've seen already has one. It's generally cable-operated by the temperature control just like the air mix flap, though some cars have a vacuum or motor operated valve.
