? about changing tire size - Fuelly Forums
Old 06-29-2007, 11:08 AM   #1
Sigifrith's Avatar
My 94 VX takes a P165/70R13 78S tire.
If I buy Bridgestone Potenza RE92's in
165/65R13 how much will the speedo & odo be
off?
To make it more interesting, what if I go to 14" HX wheels, and step up to the Potenza's in 165/65SR14?
Bridgestone shows the 14" tires as 13 Lbs. VS 19 Lbs. on the 13" tires.
[SIGPIC][/SIGPIC]
Sigifrith is offline   Reply With Quote
Old 06-29-2007, 11:26 AM   #2
Tire speed calculator
The numbers on a tire tell you its dimensions. For example, 225/70R 15 means that the tire is
225 mm wide, 70% as tall as it is wide, and fits on 15" rims
"R" means it’s a radial tire.
Other letters are speed ratings, meaning how fast the tire can safely be driven.
Original equipment Alternative tire Alternative 2 Alternative 3
width 165 165 165 155 mm
aspect ratio 70 65 65 75
wheel 13 13 14 13 inches
width 6.5 6.5 6.5 6.1 inches
tire height 4.5 4.2 4.2 4.6 inches
diameter 22.1 21.4 22.4 22.2 inches
Diameter ratio 100.0% 97.1% 101.6% 100.3%
Indicated speed 60 60 60 60 mph
Actual speed 60 58.2 61.0 60.2 mph
Old 06-29-2007, 11:26 AM   #3
Tirerack should show the numebr of revs per mile for your current tire and for your potential replacements. You can compare those numbers to see what kind of speedo/odo error you might introduce.
The 14" tire is lighter, but the 14" wheel is probably heavier.
Old 06-29-2007, 12:31 PM   #4
brucepick's Avatar
There are some fine tire calculators on the web. Here's my curent favorite:
http://www.wickedbodies.net/Tire-Size-Calculator.htm
Another very good one:
http://www.miata.net/garage/tirecalc.html
iphone experience bearmeister Fuelly Web Support and Community News 5 02-10-2010 10:25 PM
NMG (Sparrow) owner "first 1000 miles" report MetroMPG Electric and Solar powered 8 03-25-2007 07:22 PM
Pig Oil wins again! Silveredwings General Discussion (Off-Topic) 16 11-22-2006 04:00 PM
Neutralizing Our Environmental Impact SVOboy General Discussion (Off-Topic) 9 09-01-2006 06:23 PM
VX -- Del Sol engine swap GasSavers_moses General Fuel Topics 28 01-06-2006 03:38 PM
