belly pan teaser pic - Fuelly Forums
Old 11-11-2006, 09:39 AM   #1
lovemysan's Avatar
belly pan pic Updated!
got started this morning
Todays progress. Kinda slow going, its cold on the garage floor.
Initial numbers are
water temp up 5 degrees
HAI IAt up 15 degrees( HAI now producing 85 degrees over ambient)
Mileage no conclusive data of course. Seems to be up slightly. 52 mph- 6 tps- 57-62mpg. After 15 minutes of driving outside temp low 40s.
Materials are aluminum trim coil(for making vinyl siding trim) And patio door screen frames
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 11-11-2006, 10:31 AM   #2
O your such a tease.....
Old 11-11-2006, 11:52 AM   #3
Looks promising!
Old 11-11-2006, 12:09 PM   #4
UfoTofU's Avatar
Looking real good.
What is that you used for the crossmembers?
- UfoTofU
UfoTofU is offline   Reply With Quote
Old 11-11-2006, 12:36 PM   #5
lovemysan's Avatar
So far some junk I found laying around the shop. Those pieces are parts to a bottom garage door seal. The rest will be patio screen door frames.
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 11-11-2006, 01:11 PM   #6
UfoTofU's Avatar
Excellent! Looks like it's going to work great. I like being a "cheapskate".
I sourced my parts for my grill block from an alleyway and some election signs that had blown over in the wind. Some of the stuff I did have to buy like the caulk (which necessitated a caulk gun) and the Zip-Ties.
- UfoTofU
Old 11-11-2006, 02:53 PM   #7
Right on - I love the reused stuff.
You should consider integrating front tire spoilers now that you have a platform. EG Honda Insight:
Old 11-11-2006, 02:58 PM   #8
lovemysan's Avatar
Yes they will be there. along with side skirts and wheel skirts
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 11-12-2006, 07:48 AM   #9
Your parents are going to be so pist when they come home and find their patio doors gone.
if they complian and are old you can say ?Dad ,, you never had screen doors at this house , it was the old place ,,remember......?
That way you can get free building materials and screw with they brains at the same time.
Old 11-12-2006, 09:21 AM   #10
MAN I am definately going to get under mine this winter when I get into the garage and so some belly pan work. Mostly in the rear where the rear lowers are hanging and the fenders are wide open to all sorts of weird air flow. I may even do a hidden front grill block that can be remotely opened and closed by cable. One problem I found out about last winter is that as you make the gas mileage go up the amount of heat available for the cabin goes down.
Add driver to car already in garage, for shared car ssquid Fuelly Web Support and Community News 1 01-05-2013 01:10 PM
Joint Membership with GasBuddy? Badams Fuelly Web Support and Community News 2 07-01-2011 11:14 PM
Browse by MPG, etc pixelwiz Fuelly Web Support and Community News 1 08-12-2008 12:26 AM
IAT Sensor Mod (Resistor Mod) SVOboy General Fuel Topics 28 10-17-2005 06:08 PM
Got my headers today & question 'bout crank scrappers b1gmoose General Fuel Topics 8 10-08-2005 09:49 PM
