Block Heaters - Page 5 - Fuelly Forums
Old 10-14-2006, 06:14 PM   #41
TANGOJETTA's Avatar
I have one those 1000watt Zerostart coolant heater, it's best thing since slice bread. When I do my FE runs I make sure I plug it in. If I don't plug it wintertime I loose 15% in FE in my 33mile commute.
TANGOJETTA is offline   Reply With Quote
Old 10-15-2006, 01:01 PM   #42
Larry, FYI for comparison, here's what I wrote after I installed my EBH:
Plugged in for an hour and a half to 2 hours, the engine temperature reads 40-50 F above ambient temperature at start-up, according to the ScanGauge.
The other Metro owner using the inline hose heater said he only noted a 10 degree F increase (also SG equipped), despite the coolant boiling away vigorously in the hose. (edit: he didn't say what the wattage was or how long it was plugged in - but I'd guess an hour)
Old 10-15-2006, 01:11 PM   #43
FE nut
diamondlarry's Avatar
I saw what looked like a 20 degree above ambient this morning. I also noticed that the radiator tank seemed a bit warm too. If anything, maybe the hose heater will allow for quicker warm-ups.
Edit: I may have to break down and have a frost-plug heater installed.
2007 Prius,
Team Slow Burn
Old 10-15-2006, 02:51 PM   #44
I bought an engine block heater several weeks ago. It has an element that fits inside the block...so I guess that would be considered a "frost plug"?
I haven't installed it. I think that it would be difficult to do myself, and I am short on cash, so have been procrastinating. Right now I will have to stick with the taped up front end to decrease warm up time. Can't wait to get it installed.
GasSavers_James is offline   Reply With Quote
Old 10-15-2006, 07:25 PM   #45
FYI, did another check on EBH warm up this evening before going to visit friends:
@ 50 F ambient...
83 F - as seen on the SG1 - after 1 hr
90 F - as seen on the SG1 - after 1.5 hrs
Old 10-15-2006, 08:34 PM   #46
GasSavers_Randy's Avatar
When it gets cold I use a normal 1500 watt heater in the car. I plug it in about 45 minutes before I leave, so it gets nice and toasty.
Once I start it I set it to full heat recirculate. The car cools back down, but dumps all that heat into the engine. It seems to heat up a bit faster. Obviously less effective than a block heater, but there's no installation.
GasSavers_Randy is offline   Reply With Quote
Old 10-15-2006, 08:56 PM   #47
On my car, i have a plug in with a timer on it for the block heater that turns on just before i wake up. Then about 15 minutes before i leave, i have a little space heater inside that car also on a timer. That kicks in WHAMO a nicely warmed up car with no excess engine wear or wasted fuel and actually less work on my car, (i don't have to run outside) just unplug the two cords and off i goo
View model averages? unicrombie Fuelly Web Support and Community News 4 11-09-2011 06:32 AM
gallons purchased or gallon capacity? Rangel59CTD General Fuel Topics 2 02-13-2011 12:17 AM
Toyota Grand Prius krousdb Automotive News, Articles and Products 5 07-26-2006 02:44 PM
Smokey Yunick's hot vapor cycle engine GasSavers_maxc General Fuel Topics 0 06-09-2006 05:20 AM
New forum guidelines, FAQ Matt Timion Fuelly Web Support and Community News 14 05-21-2006 06:26 AM
