Correct me if I'm wrong... - Fuelly Forums
Old 09-30-2007, 05:31 PM   #1
KARR's Avatar
Country: Portugal
Greetings!
On a forum about cars it's in discussion if driving in neutral will get 0 L/100 km or "infinite" MPG. It's been said that when a gear is selected mecanical energy from the wheels will keep the engine running on a steep furface, without using a single drop of fuel...
I'm not getting crazy am I? This is not true, right...??
KARR is offline   Reply With Quote
Old 09-30-2007, 05:43 PM   #2
It is indeed true. The engine becomes an air pump.
Old 09-30-2007, 05:45 PM   #3
Modern cars with computer controlled fuel injection will stop feeding fuel to the engine when the throttle is released above a certain RPM (usually above 1500).
Old 09-30-2007, 05:47 PM   #4
KARR's Avatar
Country: Portugal
But how can the engine be running without fuel being injected?
Old 09-30-2007, 05:48 PM   #5
It's an air pump powered by the wheels. Normally the engine causes the wheels to roll, at this point, the wheels rolling is causing the engine to rotate.
Old 09-30-2007, 05:49 PM   #6
trebuchet03's Avatar
Agreeing with those that have spoken thus far If it did put fuel in there, you wouldn't be able to engine brake as you do now
Keep in mind that the energy necessary to keep the engine spinning is coming from the momentum your car has -- as SVO said, that momentum is being transfered through the wheels, transmission, etc. and into your engine.
Driving in Neutral, however, will consume however much fuel needed to idle the engine
11/12
Old 09-30-2007, 05:51 PM   #7
KARR's Avatar
Country: Portugal
To all of you, thanks a lot!
Old 09-30-2007, 05:53 PM   #8
Important to note this applies to manual transmissions. I'm not sure it applies to automatic transmissions when the torque converter is unlocked.
Old 09-30-2007, 05:55 PM   #9
omgwtfbyobbq's Avatar
Same except the fluid coupling means more energy is lost via the trans.
Old 09-30-2007, 06:20 PM   #10
Welcome
By the way, welcome to GasSavers...
Nice car! This year, we get the Astra as a "Saturn Astra", but without the diesel option.
I think you may be our first Portuguese member, so a special welcome is in order!
How is 'Average MPG' Computed GoZoner Fuelly Web Support and Community News 5 02-18-2012 09:48 AM
Annual reports - Nice touch Draigflag Fuelly Web Support and Community News 0 01-01-2012 07:47 AM
Can't find the HTML for our MPG badge image scshelton Fuelly Web Support and Community News 4 06-30-2010 01:08 PM
Kansas City GasSavers_katman General Discussion (Off-Topic) 1 05-27-2006 09:01 AM
