lca13's 93 California VX Thread - Page 7 - Fuelly Forums
Old 04-15-2008, 04:04 AM   #61
In recent years they have designed the caliper seals to provide some retracting force on the pads so the drag is reduced. Absolutely have the rotors turned to minimize drag. I have seen replacement rotors that were warped 20 thou. We turned them whether they were new or reused.
regards
Gary
Old 04-15-2008, 09:45 AM   #62
Really? That's great. I wonder if there are any that we could retrofit to our brakes.
Hondork is offline   Reply With Quote
Old 04-15-2008, 12:00 PM   #63
suspendedhatch's Avatar
Originally Posted by Hondork View Post
The pads on your disc brakes are always in contact with your rotor. They don't retract when you take your foot off the brake, they just stop squeezing. The calipers do not have any mechanism for retracting, that is why you have to force the piston back when you put new pads on. Disc brakes always have some amount of friction (beyond the fact that our front brakes are tied to the tranny/engine as TomO pointed out).
So what we gassavers really want are drum brakes all around. Unfortunately there isn't a reasonable swap for this. I don't know of any front wheel drive cars with drums up front, they just don't work as well. Maybe Honda or Toyota will come up with a "no braking/no friction" disc brake set up one of these days.
If you're looking for front drum brakes you can get the old Beetle. It's not FWD but it's Rear engine so you don't have the drivetrain losses like you do with RWD or AWD.
Drum brakes up front is really unsafe. Drum brakes suck, they only persist because they're cheaper to manufacture. But they can fill up with water. They easily overheat. They're overly complicated. Nobody here wants to trade safety for mileage.
Disc brake rotors supposedly "beat back" the pads. But yes it is true that they drag some especially on older calipers. Honda doesn't make the best brakes in the world, but they're also not the worst.
I'm pretty sure the OP could have saved some grief if he had found a "B18C into a VX" swap guide and worked backward. They convert the 5 wire O2 to 4 wire.
There is nothing to fear from "15 year old wiring". The wiring itself should be as good as it was when new. Sure, the tape is dry and cracked in places...
Old 04-18-2008, 03:23 PM   #64
Hey, I drive a Metro!
Sorry I couldn't resist....
GasSavers_mango is offline   Reply With Quote
Old 05-03-2008, 06:50 PM   #65
Originally Posted by garyhgaryh View Post
Mango, where do you live? I bought a fed vx ecu a few months back. I haven't done the conversion yet, but am planning on doing it this year. If you live in the bay area (CA), we could get together and work on the conversion. I'm in need of a connector and the o2 sensor.
gary, that is very nice of you to ask. I would definitely like to be part of a swap so I can get more info on doing my own! Unfortunately, I live in San Diego. Thanks again and best of luck! Please post back with how it went after alls said and done.
Old 07-03-2008, 01:15 AM   #66
garyhgaryh's Avatar
Wow, I haven't been back in a while and there are a handful of replies. Hey guys, can you take a picture of your new O2 connectors?
Gary
garyhgaryh is offline   Reply With Quote
Old 08-31-2008, 10:11 AM   #67
I wanted to post my extrodinarily easy and positive experience converting a 1992 Civic VX California emissions to a 49 state Federal lean burn version.
As posted elsewhere, many (all?) 1992 CA Civic VX's came with the 5 wire o2 sensor installed and that included mine, so nothing to do there. The only thing I had to do was to unplug the exisiting CA ecu and replaced it with a used 49 state ecu that I purchased.
Done, perfect, immediately have a fed version lean burn mode Civic VX. This will go down as one of the easiest modifications with a big impact that I have ever done.
Just so you guys now that this swap out can be stunningly easy to accomplish given certain senarios.
SCoupe is offline   Reply With Quote
Old 01-11-2011, 09:09 PM   #68
Re: lca13's 93 California VX Thread
IM glad to be part of this forum and love my vx.... im in the bay area california and would love to do this hopefully easy swap out can anyone help me?
HIGHGROOVE is offline   Reply With Quote
Let the games begin! Matt Timion General Fuel Topics 4 12-11-2021 11:04 PM
partial fuel up... pbfoot Fuelly Web Support and Community News 6 12-29-2013 10:54 PM
WTB - Civic VX Rims UfoTofU Wanted to Buy 22 06-21-2007 05:46 PM
Questions about PCV Compaq888 General Maintenance and Repair 28 06-09-2006 06:27 PM
