05-15-2008, 09:47 AM
lightweight wheel question?
i recently got 2 vx rims, and put them at the front, since my civic is a fwd car.
on the back i got the 13' steelies that weigh about 5 pounds more each. does the rear matter as much as the front since its a fwd car? im thinking that the unsprung weight matters most at where the car is powered at. if adding vx rims to the back will make a huge difference such as the front, i will get 2 more vx rims.
05-15-2008, 09:51 AM
Might get tail happy on uneven surfaces. Ultimately though, the motor drives all 4 wheels, so you're probably getting half the benefit.
05-15-2008, 09:53 AM
Sprung vs unsprung only makes a difference to handling/ride, not to acceleration or fuel economy.
05-15-2008, 09:58 AM
I heard somewhere that every pound saved in the wheels is about 10 pounds saved at the car
05-15-2008, 10:22 AM
Similar statements are made about rotating mass on bicycles, but proper theory, experimentation, and measurements prove that it's not true.
05-15-2008, 03:53 PM
It is more beneficial to reduce rotating mass, but how much more beneficial varies from case to case.
Excluding handling & ride, your two lightweight wheels will have the same effect on the front or rear.
05-15-2008, 04:07 PM
got it.. im going to search for 2 more vx wheels. after switching from my normal 15 pound steelies to vx's in the front, i now can accelerate from 3rd gear at under 10 mph, without bogging. what a difference.....
05-15-2008, 04:13 PM
Hmm, I would think putting light wheels on the powered wheels would be alot more beneficial than putting them on the non-powered wheels.
Heavy wheels would need more "umpf" to get spinning, whereas the rears are just trailing along..
05-15-2008, 04:32 PM
In both cases it is the engine doing the spinning.
It does not matter front or rear, seriously.
05-15-2008, 04:50 PM
Unless you just want to do burnouts.
