MPFI Swap CRX - Page 3 - Fuelly Forums
Old 02-06-2007, 04:14 AM   #21
UfoTofU's Avatar
Would I only need the air box and the tube from the airbox to the IM from the Si or would I also need the resonator and air intake tube as well?
- UfoTofU
UfoTofU is offline   Reply With Quote
Old 02-06-2007, 05:10 AM   #22
You should only need the intake arm. That's all I needed.
Old 02-06-2007, 05:11 AM   #23
UfoTofU's Avatar
Just from the intake box to the IM?
- UfoTofU
Old 02-06-2007, 05:27 AM   #24
Yep.
Old 02-14-2007, 11:57 AM   #25
UfoTofU's Avatar
I have an IM from a '92 Civic d15b7 engine, it has the injectors.
The IM that I got from the '88 CRX Si also came with the injectors.
Would I be able to use the '92 injectors in the IM that I just recently got from an 88 CRX Si and bypass the need for a resistor box?
- UfoTofU
Old 02-26-2007, 08:47 AM   #26
UfoTofU's Avatar
I ordered a resistor box off a guy on honda-tech. Gathering pieces for my MPFI swap in my 88 CRX DX. I currently have :
- 88 CRX Si intake manifold
- 88 CRX Si ECU (PM6)
He sent me the "Silver Twinkie" style one rather than the boxy one on the left.
Can I use this one or do I need the other type? Hard to see in the pic but the one on the right has a "95" printed on it. Hopefully that doesn't indicate the year because I am pretty sure that I need a resistor box from an 88-91 Si or 88-89 integra.
- UfoTofU
Old 02-26-2007, 10:22 AM   #27
I think the twinkie style is the original, but I'm not sure, I'm not using one. You could always test the resistance.
Small issue with fuel entry, leading zero metalfan49 Fuelly Web Support and Community News 1 08-07-2013 07:08 AM
How to change fuel type JayHoe Fuelly Web Support and Community News 3 06-15-2011 12:14 AM
More vehicle models EmptyH Fuelly Web Support and Community News 2 08-18-2008 06:13 AM
what will the scangauge fit? GasSavers_Ryland Hypermiling 11 03-29-2006 07:15 PM
Friction Reducer kjvman General Fuel Topics 1 01-22-2006 06:52 PM
