OBD2 tool - Page 7 - Fuelly Forums
Old 12-18-2006, 08:36 PM   #61
DRW
"Then there are the tuners who burn new ROMs for OEM units."
Why are my ears burning?
I could go on for hours about the ways the ecu de-tunes the power delivery in certain areas to make it feel smoother and more controllable for the masses, but I might start to sound like a ranting conspiracy theorist!
So let's just say that the auto manufacturers might be more concerned with consumer satisfaction than maximizing FE or power at all rpm/throttle openings.
Dave W.
Old 12-18-2006, 08:44 PM   #62
Tuning a DSM costs too much. Go honda!
Old 12-18-2006, 08:46 PM   #63
Tuggin at the surly bonds
Silveredwings's Avatar
I wish I knew more about the things that can be done by reprogramming.
Old 12-18-2006, 08:48 PM   #64
You're a bimmer man, you can rechip your car very very easily, time for you to learn.
Old 12-18-2006, 08:50 PM   #65
I don't know that TLA so can you elaborate?
Old 12-18-2006, 09:07 PM   #66
TLA!? Iono what it means, but mehbe you're asking about DSM? It's a term for eclipses and such, diamond star motors I believe.
Old 12-18-2006, 09:09 PM   #67
TLA=Three-Letter-Acronym
Old 12-19-2006, 05:09 AM   #68
We already know you're nuts, so fire away!
In your opinion, between 1000 and 3000 RPM where I usually live, think there's room for improvement in my 993cc engine's ECU? (That RPM range probably rules out the engineers' concerns about making it "controllable" )
Note I don't want to increase NOX emissions.
Old 12-19-2006, 10:37 AM   #69
I didn't see this before and you're prob right. Where would I start to get edumacated? TIA.
Old 12-19-2006, 01:14 PM   #70
CoyoteX's Avatar
If you wire up a knock sensor to your stereo and play with your timing you can see there is a lot of economy to be had under 3000 rpm on a Metro. The factory tuning is not really tuned for economy at all it seems like. I can actually drive 45mph/5th gear with the timing 20 degrees advanced without knock steady state. My vacuum readings with that much advance are a lot higher than normal so I know it is getting much better mileage. It knocks under load real bad like that though so it isn't drivable other than to experiment.
Sadly the only people that know the timing and fuel maps for a metro ecu want to sell chips and are not interested in letting anyone know the map locations in memory so there is no way for me to tune the stock computer without a lot of effort to decipher the maps. The factory computer is pretty limited anyway so for a metro to get better tuning you need a megasquirt computer and a wideband O2, EGT, and knock sensor. Then you can run lean burn 18:1 ratio all you want
Fuelly Mobile Location Data xbadcrcx Fuelly Web Support and Community News 4 06-29-2011 05:00 AM
How Much Is The Average Price For "minty Clean Vx Wheels"?? panamacolin General Fuel Topics 5 08-23-2007 06:44 PM
2006 xB grille block panels installed GasSavers_Graeme Aerodynamics 7 06-28-2007 11:49 AM
ScanGauge Hockey4mnhs Hypermiling 0 02-05-2007 06:01 PM
OLED's are here - Organic Light Emitting Diodes GasSavers_DaX Automotive News, Articles and Products 4 04-20-2006 04:14 PM
