P&G and cat temperature cycling? - Fuelly Forums
Old 06-06-2008, 07:18 AM   #1
Exclamation P&G and cat temperature cycling?
I was logging some data this morning, and saw that in many P&G cycles, my catalytic converter temperature goes from ~500 degrees C to ~850 C and back. Even in more typical ones, there's still a ~250 degree C spread. Could all this heat cycling cause early failure?
Could the spread be much larger today because of wet weather, and on a dry day with no splashed water cooling the cat it wouldn't vary as much?
I'm not too concerned on my VW because it will be covered under warranty long after I return the car from its lease, but it may be bad for my truck and it may mean more to others here...
Old 06-06-2008, 12:57 PM   #2
kamesama980's Avatar
I've only heard of damaging a cat through rich/oil burn (clog), melt (lean), or mechanical (hit it) damage. it's meant to take sub-zero to 900+ degree temperature cycling day in day out, I doubt 500-850 (which is 350 difference btw, not to be nit-pickey or anything :-p) is gonna bother it.
Old 06-06-2008, 03:34 PM   #3
My concern was the quantity of heat cycles. In general usage, it heats up and fluctuates much less during use than with P&G.
The 250 number was for "more typical" P&G cycles than the ones that resulted in the 350 difference.
Old 06-06-2008, 04:00 PM   #4
There's really only one way to be sure.
"I say we take off and nuke the entire site from orbit." -Ellen Ripley
94 Altima 5 spd.. Stock.. 29 mpg combined with basic hypermiling techniques ..
89 Yamaha FZR400 Crotch rocket, semi naked with only the bikini fairing, no lowers, 60 plus mpg
87 Ranger 2.3 5spd.. Does not currently run..
fumesucker is offline   Reply With Quote
Old 06-07-2008, 04:27 PM   #5
My point was that 900*+ sweeps do no appreciable damage over 20 years in a healthy engine. zero times fifty is still zero
Old 06-07-2008, 04:49 PM   #6
Well, I'll let you know in 40,000 miles when I turn in my lease.
Add Groups? ScoutTech Fuelly Web Support and Community News 3 03-17-2010 10:35 PM
CL 1993 Geo Metro XFi GasSavers_Red For Sale 2 08-06-2007 04:30 PM
