People with MPGUINO - Page 2 - Fuelly Forums
Old 02-05-2010, 11:42 AM   #11
Sounds good, I think I may order one. Thanks for the reply everybody, I got the answer that I was just looking for.
GasSavers_viperguy is offline   Reply With Quote
Old 03-28-2010, 08:42 PM   #12
Is there anything of the nature for a carbbed car ('88 festiva)
odiekokee is offline   Reply With Quote
Old 03-29-2010, 04:29 AM   #13
With a carburetor, AFAIK there's no decent way to measure fuel usage. A vacuum gauge might give you some useful information; you could either try to keep vacuum high, which means that you're driving slow, or you could try to keep it low which means that you're not wasting fuel pulling a vacuum.
Old 03-29-2010, 05:15 AM   #14
In my experience the Festiva is a car that gets about the same milage no matter how it's driven
Old 03-30-2010, 03:09 PM   #15
I can attest to that. I get 39-40 regardless...and that's with a huge crankcase blowby and leaky oil. worst i've gotten was 36. I've got a vac gage, usually pulling 3-5 (not sure if that's in or mm of mercury) at 75mph. not quite WOT but near it.
Old 08-12-2010, 03:44 AM   #16
Re: People with MPGUINO
Alright, I'm looking at one of these as an option for my '90 Laser 1.8L but on their wiki page they do not list the parameters you set for accuracy for any DSM except the 1990 Mitsubishi Eclipse 2.0L Turbo model.
What type of hurdle does this present? Would it be a guessing game to dial it in?
John
'09 Saturn Aura 2.4L
'96 Chevy C1500 (5.0L 5sp)
'01 KTM Duke 2
Old 08-12-2010, 06:09 AM   #17
GasSavers_WD40's Avatar
I thought I read somewhere that it would show when my VX was in lean burn mode.
Maybe those with a VX could pipe in?
GasSavers_WD40 is offline   Reply With Quote
Old 08-12-2010, 08:30 AM   #18
Not a big hurdle as usually you have to fine tune it anyway. Basically you would just start with either something generic or just use the 2.0 Turbo numbers and calibrate it over a few tanks (which is SUPER easy, first tank/calibration should get you pretty close).
Here is the directions you would use to calibrate it and dial in the accuracy in case you missed it: MPGuino Calibration
As for the VX lean burn... I do not think it shows this specifically, I think you could probably just watch the Gallons/Hour number and when it drops (under same throttle position), you hit lean burn.
ben98gs is offline   Reply With Quote
Old 08-13-2010, 03:05 AM   #19
So it's like dialing in the ScanGaugeII? Just adjust what it estimates your fuel useage is after the first few fillups?
Seems like a cheap price for such a product. Granted, it's not a SGII but its close.
John
'01 KTM Duke 2
Old 08-16-2010, 03:31 AM   #20
I have not used a ScanGaugeII, but if that is the way it works, then yes, the MPGuino is very similar.
You are right, that it is not a ScanGauge, but the MAIN point of the MPGuino is that non-OBDII cars can use it. You cannot use a ScanGauge with my car, and thus I built my own MPGuino instead.
150x150 sig davejsw Fuelly Web Support and Community News 2 05-22-2009 06:50 AM
Driving improving FE? Nate R Hypermiling 9 04-11-2008 07:32 PM
removal of factory air dam 91CavGT Aerodynamics 2 08-27-2007 06:54 AM
100 mpg car? minic6 General Fuel Topics 42 08-11-2007 07:49 AM
Any guess on what MPG gains I'd get if I removed power steering and air conditioning? cheapybob General Fuel Topics 24 04-27-2006 04:11 AM
