recently purchased '99 HX w/ poor FE - Fuelly Forums
Old 08-24-2011, 08:52 AM   #1
Hello. I recently purchased a 1999 Civic HX after losing my CX when someone pulled out in front of me. I averaged 38mpg with the CX. I commute about 70 miles a day, 90% is highway. A/C on 50% of the time. Averaging 70mph. I'm averaging 32mpg after 5 tanks of gas in the HX. It has a manual trans, 217,000mi (30k on rebuilt motor) and steel wheels. First thing I did after buying it was get an oil change. I haven't done anything else yet other than new shocks/struts and tires.
What should I be looking for in trying to improve my numbers?
cured1 is offline   Reply With Quote
Old 08-24-2011, 01:12 PM   #2
GasSavers_Erik's Avatar
Re: recently purchased '99 HX w/ poor FE
Inflate tires to max sidewall rating
Jack up each wheel and spin it to be sure that a brake isn't dragging.
See if there are any stored codes on your ECU related to the oxygen sensor.
Old 08-24-2011, 01:13 PM   #3
tradosaurus's Avatar
Tire pressure to max sidewall.
Check spark plugs, cleanliness and gap.
Fuel filter change.
Air filter check.
tradosaurus is offline   Reply With Quote
Old 08-24-2011, 01:22 PM   #4
slow down. 70mph will not yield great numbers even if the car was in "like new" condition!
Old 08-24-2011, 03:11 PM   #5
add|ct's Avatar
Yes, probably at 70 MPH, the lean-burn feature is not being used.
'92 Civic VX, Canadian model
Old 08-24-2011, 03:47 PM   #6
What year was your CX?
The 1999 HX is rated a respectable 30/38. I expect your 70mph 50% A/C should do better than 32.
Do you know if the car has been modified? For example, is the gearing what it should be?
How about that engine rebuild...was it done to OEM spec or was it done with the intent of increased performance?
Old 08-24-2011, 04:05 PM   #7
Check all hoses, check for vacuum leaks. check plug wires.
1cheap1 is offline   Reply With Quote
Old 08-25-2011, 07:36 AM   #8
Thank you for the responses.
My CX was a 1994 model. I do not think the HX has been modified and I am unsure about the engine rebuild info.
I'll have a look at all that was suggested.
Old 08-25-2011, 12:36 PM   #9
Oh and don't forget one of these must have's for fuel efficiencies:
Old 08-25-2011, 03:59 PM   #10
updated upper grille block Philip1 Aerodynamics 6 07-30-2008 03:36 AM
I hear crickets GasSavers_davens General Fuel Topics 18 07-24-2006 07:01 PM
Sharing Indexing Washers SVOboy General Fuel Topics 0 04-01-2006 01:36 PM
