Tire Size - Fuelly Forums
Old 06-22-2007, 02:38 PM   #1
88HF's Avatar
Tire Size
I put 14 inch tires from an integra on my crx. How does this effect my odometer reading?
my favorite thread
Old 06-22-2007, 03:52 PM   #2
Probably makes it incorrect.
You have to know the previous size and the new size, and compare it. Do a search on this site for "miata" and you'll find a tire size calculator.
Old 06-23-2007, 09:12 AM   #3
88HF's Avatar
Thanks that helps alot heres the url for anyone else searching: http://www.miata.net/garage/tirecalc.html
now I have to change my garage entry to reflect the difference.
my favorite thread
Old 06-23-2007, 09:20 AM   #4
mrmad's Avatar
My 90 CRF HF has 14" rims with 185/60/14 tires. I used this http://www.discounttire.com/dtcs/infoTireMath.dos calculator and got an approximate 5% difference between the stock size.
I then measured a 28 mile distance on Google Earth between 2 exits on the freeway on my commute and found that with the 14" tires I was within 1/10 mile accuracy. From this I'm assuming the odometer with the stock sized tires is a few % high.
Old 06-23-2007, 09:23 AM   #5
88HF's Avatar
using the miata page, the difference between my stock 175/70/13s and the 185/65/14s was 3.6%. I wonder why it isn't the same on the discounttire page.
my favorite thread
Old 06-23-2007, 09:26 AM   #6
88HF's Avatar
are you using a size other than 175/70/13 as stock?
my favorite thread
Old 06-23-2007, 09:50 AM   #7
mrmad's Avatar
I never had the stock size, the car came with 14" rims with the 185/60/14 tires. According to tirerack.com, the stock size of a 90 CRX HF is 165/70/13.
Old 06-23-2007, 09:53 AM   #8
88HF's Avatar
Ok, I was just going by what was on my 90 crx. I'll have to checkout and see if the std. size for 88 is different and adjust my mileage again.
my favorite thread
Old 06-23-2007, 09:58 AM   #9
88HF's Avatar
double checked everything, with my 185/65/14s I'm driving 6.2% further than odometer reading. thanks mrmad.
my favorite thread
Old 06-23-2007, 10:01 AM   #10
mrmad's Avatar
That's what I was assuming, but if my measurements using Google Earth were accurate, it seemsmy 90 is now about spot on in odometer readings with the 185/60/14s. This makes me think the stock odometer with the stock tires reads high.
iphone experience bearmeister Fuelly Web Support and Community News 5 02-10-2010 10:25 PM
Hubcaps? DracoFelis Aerodynamics 58 03-26-2007 09:09 AM
Pig Oil wins again! Silveredwings General Discussion (Off-Topic) 16 11-22-2006 04:00 PM
Neutralizing Our Environmental Impact SVOboy General Discussion (Off-Topic) 9 09-01-2006 06:23 PM
VX -- Del Sol engine swap GasSavers_moses General Fuel Topics 28 01-06-2006 03:38 PM
