Valve timing "experiment" - Page 3 - Fuelly Forums
Old 02-01-2007, 04:31 PM   #21
FE nut
diamondlarry's Avatar
Originally Posted by lovemysan View Post
Crud! Your worthless!
well not really. You did send me instructions about the kill switch. Well anyways I think your supposed to use some type of shim stock and the bolt washer keep it from sliding out of the cam gear. I need to find that stuff.
Do you have anyidea how long it would take to get the cam gear off my sohc? I'm a competent mechanic and have done a cam swap on a my nissan.
Now you see why I was assinged the non-critical jobs. Anyway, the hardest part will probably be getting everything out of the way to get the front cover off; power-steering, A/C, top enginge mount, etc. You will also make it easier on yourself if you jack up the car and take off the right front wheel and the inner fenderwell. Then you'll have to get all of the bolts out of the cover. It seems like there were some small bolts/screws down by the oil pan that could easily be missed. Then you have to pry up a little on the front cover then out. Using air tools like we did, you could probably have the gear exposed in an hour but, the first time you do it, plan on longer. Also, make sure there are no women or small children around in case of a slip of a naughty word or two. I did quite well on that though.
2007 Prius,
Team Slow Burn
Old 02-01-2007, 04:39 PM   #22
GasSavers_Ryland's Avatar
offset timing gear key
insted of filing your timing gear to death, or buying an adjustable timing gear, I'm pretty sure I've seen offset keyway keys, and the differnt offsets give you differnt degrees of change.
Old 02-01-2007, 04:42 PM   #23
FE nut
The problem is going to be finding things like that for a SOHC. There isn't as much of a market for SOHC performance parts since most people are modding the DOHC.
2007 Prius,
Team Slow Burn
Old 02-02-2007, 07:33 PM   #24
lovemysan's Avatar
Well what I want to do would definately not be considered a performance mod. Well its sounds like its not possible to pull the gear from the top so I won't be able to do this. I can't spend a whole day taking apart a 64,000 mile engine fiddling with critical engine components. My family already thinks I'm a nut for attaching parts and removing spoilers on a practically new car. They actually made me sign a contract stating I wouldn't modify the car when I bought it.
My nissan was just plain easy. Take the valve cover off, unbolt/slide gear off and secure chain, remove cam caps, remove cam, reassemble was reverse process. Just press the oil pressurized tensioner back in and bolt together. I did the last in around 15 minutes on a nice warm engine.
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 02-02-2007, 07:50 PM   #25
skewbe's Avatar
Yah, it's been my experience that my sw2 is a PITA to work on also. Though I remember one particularly nightmareish starter motor on a stanza, took like 6 hours. It was like they built the car around the starter motor or something
Standard Disclaimer
Old 02-02-2007, 08:54 PM   #26
FE nut
I talked to Mike yesterday and he said that there is enough room to get at the gear without taking the front cover clear off. You can pry the cover out just enough to allow access to the bolt that holds the gear on. He did say that if you end up dropping the bolt that you will end up having to take it clear off anyway.
2007 Prius,
Team Slow Burn
Slightly annoying sort order on 'View all fuel-ups' lowlevel Fuelly Web Support and Community News 2 11-25-2010 08:04 AM
Log your Cycling/Running on Fuelly? kclark987 Fuelly Web Support and Community News 1 09-21-2010 01:57 AM
some more familiar driving, LOL Compaq888 General Discussion (Off-Topic) 20 04-07-2009 01:37 PM
BMW C.L.E.V.E.R. Concept MetroMPG General Fuel Topics 4 04-24-2006 10:59 PM
