10-22-2005, 11:49 AM
Water Injection
<a href=http://website.lineone.net/~da.cushman/misc/mannject.html target=_blank>A big nice thing on water injection</a>
This is well worth the read, I really wanna do this, I think I need to make a list of crap to do pretty soon.
10-22-2005, 02:07 PM
More water injection
My
<a href=http://www.yarchive.net/car/water_injection.html target=_blank>More water injection</a>
My gosh, it's sounding better every minute.
10-22-2005, 02:54 PM
Quote:This is some info and
This is some info and experiences with using water injection (by
vacuum) with a Toyota 1.5 L carbed engine in good condition:
* with this carb, there is a R port that is situated right above the
throttle plate and can be used to control water flow so that there is
little flow at idle.
* had trouble regulating the flow and so had flows of anywhere from
25% (1 to 4) to 2% (1 to 50) water to gas ratios. Yes the car ran on
1/4 water using Bosch single electrode plugs with a slight miss under
hard acceleration for 50 miles.
* when testing the acceleration of the car in 5th gear from 25 to 60
MPH...I found that the time required to reach this speed with a 2%
injection rate was 13% greater with the water than without....meaning
around a 13% loss in "power".
* also have seen no increase in MPG and maybe a slight loss.
* have noticed a reduction in oil used over the last 4500 miles (3500
with water injection) and am assuming that the rings/valves have been
steam cleaned, thus improving oil use from 5K per quart to around 9K
per quart.
** during this period of using water injection I also used Marvel
Mystery Oil as a top lube, putting it in the gas and also used a PCV
jar.
** my impressions of the water injection is that it does smooth out
the engine, but it does so by reducing burning temps and thus
power...so considering no MPG gains, the trouble of keeping it going
and possible damage to the carb...I probably won't use it.
** I am going to try using it on occasion for cleaning the engine
though....using a 1 to 8 mix of water to MMOil and with a few
drops of dish detergent to keep it emulsified...running it thru the
same port at around 5%...maybe a gallon at a time.
>> posted as information only....use at your own risk.
10-22-2005, 04:28 PM
DIY Water Injection
<a href=http://www.dawesdevices.com/water.html target=blank>DIY Water Injection Instructiona</a>
10-22-2005, 04:38 PM
How-to
Installation
<a href=http://www.dawesdevices.com/howto.html target=_blank>How-to</a>
<a href=http://www.dawesdevices.com/waterinst.html target=_blank>Installation</a>
10-22-2005, 04:46 PM
More!
<a href=http://www.motherearthnews.com/menarch/archive/issues/059/059-046-01.htm target=_blank>More!</a>
10-30-2005, 09:02 AM
Another DIY Solution
<a href=http://www.motherearthnews.com/library/1979_November_December/Ron_Novak_s_Do_It_Yourself_Water_Injection_System target=_blank>Another DIY Solution</a>
10-30-2005, 09:24 AM
Damnit, someone try this
<a href=http://www.dave-cushman.net/misc/mannject.html target=_blank>Damnit, someone try this already, it has great potential</a>
02-16-2007, 07:04 PM
Kicking an old thread into existence again....any new information on this topic? Did a search, it appears that no one has tried anything for a year or two now...
02-16-2007, 08:24 PM
This looks like a reasonable summary:
http://en.wikipedia.org/wiki/Water_i...7;28engines%29
Works great if injecting into a turbo, Normally aspirated engines needs more tweaks (lean out for FE, advance timing for power).
