Weight reduction: not filling the gas tank - Fuelly Forums
Old 08-23-2006, 03:21 AM   #1
krousdb's Avatar
Originally Posted by MetroMPG
As Dan knows, you can gain an equivalent weight advantage by just not filling your tank above half way.
Yup, about 6 lbs per gallon IIRC. When not calibrating the SuperMID, I only have 6 gallons max in my 11ish gal tank. That is about 30 pounds savings. I also have my windshield washer solvent at 1/2 tank max.
Old 08-23-2006, 05:05 AM   #2
MetroMPG's Avatar
I love it. Are you running half-tanks now, or are you still calibrating the MID with the VX?
I think 6lbs/gal is what I turned up most in a recent search I did as well. Which actually makes fuel the single heaviest easily "removable" item on my car. 10.5 gal tank = 63 lbs. Spare & jack = 24. Passenger seat = 29.
Old 08-23-2006, 05:13 AM   #3
how much difference does 30lbs really make??
for what its worth, i skipped breakfast this morning. figure it was worth a couple of pounds.
Free veggie starter kit!
argylesocks is offline   Reply With Quote
Old 08-23-2006, 06:28 AM   #4
MetroMPG's Avatar
25 lbs may represent a fuel economy difference of about 0.25% - 0.5% based on the oft quoted figure of a 1-2% fuel economy penalty for every extra 100 lbs carried (EPA).
The difference is likely too small to measure reliably with FE instrumentation in a test scenario. But it's real, and every little bit helps.
However, this kind of discussion is probably an example of how we apparently cultivate the impression we're Screwballs.
Old 08-23-2006, 08:58 AM   #5
krousdb's Avatar
I love it. Are you running half-tanks now, or are you still calibrating the MID with the VX?.
I'm calibrated and running half tanks now. Can't say it it makes a difference. Can't hurt though.
Old 08-23-2006, 09:09 AM   #6
Is dan back from retirement? Retirement meaning the beach.
Old 08-23-2006, 11:10 AM   #7
GasSavers_Jack's Avatar
I make up for full filling my by just running it 50 miles after the fuel light comes on!
See my car here:
https://www.cardomain.com/ride/2452824
GasSavers_Jack is offline   Reply With Quote
Old 08-23-2006, 11:13 AM   #8
MetroMPG's Avatar
Modern cars are supposed to have closed systems. No fuel should evaporate to the outside, so you don't "lose" anything. Fumes are combusted via the evaporative emissions controls.
Old 08-23-2006, 11:17 AM   #9
kickflipjr's Avatar
I just go from F to E. I fill it up till it clicks (so I can track my mpg) and then ride till E (aprox. 9-10gal). If I do half fills it throws off the whole one click fill up thing.
2008 EPA adjusted:
Old 08-23-2006, 11:17 AM   #10
The only thing I've heard about too little gas is from lubedev/smartgas. He claims that all the water in that air will collect in gas and ruin your mileage! Logical, no?
Smart Metering Trend pb Fuelly Web Support and Community News 0 07-27-2008 03:03 AM
Calendar picker for entering fuel-up date? delfuego Fuelly Web Support and Community News 1 07-19-2008 01:18 PM
Coasting in Neutral Illegal??? 95metro Hypermiling 23 05-12-2006 05:50 AM
An American Perspective on Driving in Canada rh77 General Discussion (Off-Topic) 28 03-24-2006 09:42 PM
