Wheel Bearings - rolling resistance question - Page 2 - Fuelly Forums
Old 03-27-2008, 06:20 PM   #11
DracoFelis's Avatar
Originally Posted by Erik View Post
Draco- Good idea. I would have been worried about getting some metal shavings in the center of the bearing when the drill bit finally broke through.
How did you avoid this- magnetized drill bit?
Actually that's exactly what we did.
The mechanic put some rare earth magnets (which I happened to have around the house) on the side of the drill bit, before drilling, and didn't remove the magnets until after the drilling was done. As long as the magnets were in contact with the bit, the bit was magnetized very well.
Old 06-18-2008, 01:13 PM   #12
Originally Posted by tasdrouille View Post
Rolling resistance comes on average 82% from tires, 12% from bearings and 6% from brake friction.
where does this come from ???
COMP is offline   Reply With Quote
Old 06-18-2008, 04:49 PM   #13
Originally Posted by Silver00 View Post
I would think that if the bearings are in good condition there is little you will do to improve them. Keep in mind that when the bearings warmup the grease will thin down some and turn easier. You would most likely gain more by adding even just 1-2 psi to the tires, that is where most all of the rolling resistance is.
Sums it up nicely.
I would also add most people over lube bearings when they are serviced.
This not only wastes lube but add additional drag to the bearings.
Pete.
GasSavers_Pete is offline   Reply With Quote
Fuelly Mobile Location Data xbadcrcx Fuelly Web Support and Community News 4 06-29-2011 05:00 AM
For sale 92 VX Illinois 133k MY02WRX For Sale 46 10-23-2007 05:20 PM
On the Subject of Old VW Fuel Sipper Concepts.... trebuchet03 General Fuel Topics 3 09-26-2007 11:52 AM
195* Tstat SVOboy Experiments, Modifications and DIY 12 04-17-2007 07:27 AM
Possibly doing the unthinkable. Would like your input Matt Timion General Discussion (Off-Topic) 41 09-07-2006 10:27 PM
